newest uberdata released
Old Sep 25, 2003 | 12:29 AM
  #226
toxicshit's Avatar
Default Re: (T-RO)
thnx for the info T-RO,
but when i have a bin file from pgmfi.org how can i make it compatible with uberdata so i can use it ???
Old Sep 25, 2003 | 12:39 AM
  #227
toxicshit's Avatar
Default Re: (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Where can we get a radiohack braid? What do you mean by a very soldering iron?</TD></TR></TABLE>
i think he means a good hot soldering iron not to cold and not to hot. i think somewhere arond the 350 Degrees Celcius.
You can get the radiohack braid at anny good electronics shop. just say that you need stuff to absorb solder and the guy will know what you need.
Modified by toxicshit at 9:54 AM 9/25/2003
Old Sep 25, 2003 | 01:00 AM
  #228
rjardy's Avatar
Default Re: (toxicshit)
Bump for my question
Like this thread needs a bump.........
Rob
Old Sep 25, 2003 | 01:03 AM
  #229
T4sol's Avatar
Default Re: (rjardy)
Wow....4 days and almost 4000 views. Blake u should be proud!
Old Sep 25, 2003 | 04:37 AM
  #230
dabrown's Avatar
Default Re: My new Uberdata setup! (B94Cast)
B94/ The 29c256 chips is what I was trying to tune with on the batronix, and I received the same error you had previously. Let me know if it works for you..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B94Cast &raquo;</TD></TR><TR><TD CLASS="quote">w00t!
Now how it went... I purchased a Xicor 28c256 chip.. and could not write all of the bits. Spent several hours trying every possible combination of writes to the thing, and still the same errors - could not write to sector 0 and sector 10.
Old Sep 25, 2003 | 05:57 AM
  #231
Evil EG's Avatar
I just ordered a 29c256 from http://www.moates.net/gmecm/hworder.html (thanks to slashDEVslashNULL for the link) and I will post how it works in the Batronix unit once I get it.
On that link above if you look at the bottom of that page at S4 the 28-pin Low-Profile ZIF will that plug into the 28pin socket? Cause I want to do what that guy that had http://www.stupid-fast.com web site how he cut a whole in the ECU cover and elevated the socket so you could change chips without taking the cover off.
Old Sep 25, 2003 | 06:25 AM
  #232
B94Cast's Avatar
Default Re: My new Uberdata setup! (BVM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM &raquo;</TD></TR><TR><TD CLASS="quote">
On that link above if you look at the bottom of that page at S4 the 28-pin Low-Profile ZIF will that plug into the 28pin socket? Cause I want to do what that guy that had http://www.stupid-fast.com web site how he cut a whole in the ECU cover and elevated the socket so you could change chips without taking the cover off. </TD></TR></TABLE>
Yes, the S2 or the S4 will work for that. I also ordered the S2 - I did not like the looks of the the S4 (the way that it clamps ths chip in looks freaky!@)
Old Sep 25, 2003 | 07:51 AM
  #233
baphomet's Avatar
Default Re: My new Uberdata setup! (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">Okay so i have the program loaded on both my PC and my Lap. Here is my issue, with the PC everything is cool, i adjusted the res so i could see the entire map, but on my Lap, i adjusted it out as far as it would go, but I still cannot see the entire map to use it. Any suggestions on how to view the ENTIRE map? It's probably a pretty easything, but im kinda dumb when it comes to computers. thanks guys
Rob</TD></TR></TABLE>
there is an 800x600 version, or use a virtual resolution driver to extend your desktop.
Old Sep 25, 2003 | 08:21 AM
  #234
omahaturbocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote">
Its desoldering braid and you can get it at Radioshack. I think he means very hot iron. I use a 40 watt when desoldering and a 15 watt to solder. The braid absorbs a lot of heat and the 15 does not work very well, the hotter iron lets you get in and out quickly with less risk of damage since there is little time for the board to abosorb heat and cause damage. The 40 is too hot for normal soldering, 15watt is plenty.
Just a heads up for everyone, most people use the s4s because they are smalller and will clear everything in the case. If you are elevating by stacking the sockets it may not be a problem but if you just want a zif to put in your ecu it will need to be the s4.
Old Sep 25, 2003 | 08:54 AM
  #235
civcexcoupeblack's Avatar
Default Re: My new Uberdata setup! (omahaturbocivic)
Also been using uberdata for a couple months now. Runs like a champ. Sam and I put the three bar map sensor, and 550cc injectors in, and it works like a charm
Old Sep 25, 2003 | 09:15 AM
  #236
civperc's Avatar
Default Re: My new Uberdata setup! (civcexcoupeblack)
I'm gonna get the Willem burner, as suggested by the more knowledgeable folks in this thread, however I wanna clairfy which chips I need to get. I don't wanna buy some but then have them go haywire with an error during burning (baaaad shiznatty).
what chip should I buy like 3 or 4 of?
Old Sep 25, 2003 | 09:44 AM
  #237
T-RO's Avatar
Recommended chip is the AT29c256
It can be written on and erased with your programmer. Cost more but is easily reusable.
Cheaper is the 27c256, this neds a special UV light to erase (light can be made for less than $20 I believe)
I currently use a AT29c256 with my Willems
Old Sep 25, 2003 | 10:03 AM
  #238
civperc's Avatar
Default Re: (T-RO)
ok, I'll go with the 29c256 ones
I have another question I've come up with, heh. If I get an ecu that's already been chipped, will I be able to remove the chip in there and just pop in my 29c256 after I've put a basemap onto it? Hopefully so, cuz that'll save me soldering.
Old Sep 25, 2003 | 10:10 AM
  #239
falcongsr's Avatar
What is this crap?
Default Re: My new Uberdata setup! (Rakka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rakka &raquo;</TD></TR><TR><TD CLASS="quote">
Where in texas are u? i'm about 1.5 hours east of dallas. U can use my wideband for free if you want </TD></TR></TABLE>
hey Rand McNally, you idiot, you're west of dallas.
Old Sep 25, 2003 | 10:13 AM
  #240
Rakka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">Okay so i have the program loaded on both my PC and my Lap. Here is my issue, with the PC everything is cool, i adjusted the res so i could see the entire map, but on my Lap, i adjusted it out as far as it would go, but I still cannot see the entire map to use it. Any suggestions on how to view the ENTIRE map? It's probably a pretty easything, but im kinda dumb when it comes to computers. thanks guys</TD></TR></TABLE>
I have to add scrollbars, didnt think there were people out there so poor, that they couldnt afford a 1024x728 moniter
Old Sep 25, 2003 | 10:15 AM
  #241
R6Elmo's Avatar
Radiohack = radioshack. Thus go to radioshack to purchase it.
You need a very hot solderig iron, at least 40w
Old Sep 25, 2003 | 10:51 AM
  #242
raene's Avatar
Well, I've purchased the Willems unit... should be shipping soon. I also have a lead on a cheap P06 ECU. So next I need a new distributor, some wiring harness clips + plugs, and an O2 sensor... then socketing the chip... and I'll finally have joined the 21st century
Old Sep 25, 2003 | 11:08 AM
  #243
Rakka's Avatar
Default Re: My new Uberdata setup! (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
hey Rand McNally, you idiot, you're west of dallas.</TD></TR></TABLE>
ahh stupid me, I drive east to dallas
Old Sep 25, 2003 | 11:13 AM
  #244
baphomet's Avatar
lol pueblo, your at 70% already
Old Sep 25, 2003 | 11:42 AM
  #245
civperc's Avatar
Default Re: (untensadude)
what about ecus that have been "socketed" for hondata, is that different than chipping?
Old Sep 25, 2003 | 11:54 AM
  #246
-KangaRod-'s Avatar
This software is awesome!
I havn't used it, but rest assured I will.
It would be nice if I could spec maps past 9000. is their a particular reason why 9000 is a magic number?
Old Sep 25, 2003 | 11:55 AM
  #247
raene's Avatar
I believe it's the same thing. Just remove the chip that's in there and install the new Uberdata chip.
Someone that has more experience, please reply... PHiZ would know!
Old Sep 25, 2003 | 11:56 AM
  #248
raene's Avatar
Default Re: (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">This software is awesome!
It would be nice if I could spec maps past 9000. is their a particular reason why 9000 is a magic number?</TD></TR></TABLE>
I second that
  #249
Rakka's Avatar
Default Re: (raene)
yup, just pop it in and go!
Old Sep 25, 2003 | 12:15 PM
  #250
civperc's Avatar
Default Re: (Rakka)
w00t! I just picked up a p28 ready to accept a chip for 100 bucks.
now to buy my Willems and chip...
