newest uberdata released
Old Oct 1, 2003 | 07:53 AM
  #376
toxicshit's Avatar
Default Re: (djmatix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I burned a p30 baseline rom (found on that bank94 site or whatever it is that has an uberdata archive) The car idled crappy, it ran crappy, AND it had a 3500rpm rev limit at any speed. So I went back, burned the stockGSR bin that came with uberdata and it idled perfectly, ran perfectly, but still had that f-in 3500 rev limit. So I gave up for the night and got my 4 hours of sleep. The chips burned right, it said the information was the same on the IC as the program. I'm using an AM29c256 eeprom, and the batronix 3.3 with the newest verison of the prog studio. The JDM p30 ecu was chipped by hondata, everything is clean, and its got one of those TSM resistors (john khrome told me) wired as a jumper, and said it was pro work. So whats the deal? any help would be fine. thankS!</TD></TR></TABLE>
did you click on the apply next to the rev limits. if the stock setting was fine then klick apply. maybe you forgot to apply something ( just an idea )
Greetz Erwin
Old Oct 1, 2003 | 07:59 AM
  #377
Evil EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">ok, I got it to work lastnight with one last attempt before I went to bed....which kept me up 2 more hours.....which I had to get up 4 hours later to drive an hour to work.....damn im tired. ANYWAY
So I got the tricky bastard to work , and my shitty p2 400mhz laptop was the one that got it to work. It is a IBM thinkpad so I opened the config manager and found that the serial port was on....well it wasnt on 378f, or 278f so I changed it, rebooted and the freakin thing worked. ok so here is my problem now.
Cut the j1 jumoer and i bet that 3500 rpm rev limit goes away and if so then theres somthing wrong with either how your putting your chip in or with the soldering of all your connections.
Old Oct 1, 2003 | 09:48 AM
  #378
marlborocars's Avatar
Put the launch rev cut above the fuel cut to dissable it
Old Oct 1, 2003 | 10:59 AM
  #379
rjardy's Avatar
Default Re: (marlborocars)
So when are we going to see some tuned maps released? We now have a web site to host them on, so how about some of you guys that have your setups running well, post your burn
Rob
Old Oct 1, 2003 | 11:06 AM
  #380
raene's Avatar
Default Re: (rjardy)
I'm going to develop a website based on this thread... summarize all 13 pages of information and collate it all into a single document. Hopefully I'll have it done sometime this week Taking the FAQ to a whole other level basically... and I'd like to throw the BINs in there also.
I think people are just playing with the s/w right now and trying stuff, not 'tuning' per se... myself, I estimate I'll have Uberdata up and running in about 3 weeks. Then I can start working on buying my turbo parts
Old Oct 1, 2003 | 11:12 AM
  #381
hoggy's Avatar
I can' wait to see some tuned maps from people. This will give everyone else a better place to start.
Old Oct 1, 2003 | 12:01 PM
  #382
PHiZ's Avatar
Default Re: (FyReo3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FyReo3 &raquo;</TD></TR><TR><TD CLASS="quote">
goldjung...
I have a few different P28 roms.
I have a stock dump, in which the idle ignition timing is at 16.5.
The P28-ERM baseline rom, that came with Uberdata, has the idle ignition at 18.75.
I understand that the 92-95's had a factory ingnition timing of 16 BTDC. I also know that my 99 is at 18 BTDC from the factory.
I was just wondering if the P28-ERM Baseline rom had been adjusted to work with something similar to my car. The difference in the two is around 2 degrees throughout the timing tables.
THanks.</TD></TR></TABLE>
Good info, I'll have to remember that, I was going to use a D16Y8 tuned program on a D16Z6, now I'll pay special attention to the difference, it's especially harders, since the D16Y8 came with the P2E ecu, and it's nary impossible to find stock maps for that, due to it being OBD2
also, djmatix, I'm only john khrome on AIM, here I'm me...
-PHiZ
Old Oct 1, 2003 | 12:22 PM
  #383
baphomet's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to develop a website based on this thread... summarize all 13 pages of information and collate it all into a single document. Hopefully I'll have it done sometime this week Taking the FAQ to a whole other level basically... and I'd like to throw the BINs in there also.
I think people are just playing with the s/w right now and trying stuff, not 'tuning' per se... myself, I estimate I'll have Uberdata up and running in about 3 weeks. Then I can start working on buying my turbo parts </TD></TR></TABLE>
Old Oct 1, 2003 | 01:08 PM
  #384
Mr. Softee's Avatar
goldjung...
j davis made that rom. you will have to ask him. i am not sure why he chose to do that. seems strange.
sam
Old Oct 1, 2003 | 01:21 PM
  #385
LSturboHB's Avatar
Default Re: (94goldjungsr)
good info
Old Oct 1, 2003 | 02:15 PM
  #386
hybridb18's Avatar
Default Re: (LSturboHB)
my local radioshack has the 74hcT373 IC. Is this the same as 74hc373 IC? What does the "T" in there mean??
Old Oct 1, 2003 | 02:18 PM
  #387
raene's Avatar
Default Re: (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Don't hold your breath; I'm pretty dang busy @ work right now But I AM working on it!
Old Oct 1, 2003 | 05:38 PM
  #388
djmatix's Avatar
Default Re: (BVM)
I cant cut the jumper, this ecu was setup by hondata, so its a tcw resistor and its soldered to the board. Its kind of hard to explain. I've had chips working in it before, and I compared the IC data to the bin file and they checked out fine. Is there any roms that people KNOW are right? And also, i've found a couple of sites that have roms on them, but if you load them in the uberdata software, you'll find that people have just been messing around with the program, setting 420,000 fuel cuts...whats up with that? anyway, thanks for the help.
oh, and sorry phiz, i'll call you by the right name .
Old Oct 1, 2003 | 06:32 PM
  #389
rioninja's Avatar
Default Re: (hybridb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridb18 &raquo;</TD></TR><TR><TD CLASS="quote">my local radioshack has the 74hcT373 IC. Is this the same as 74hc373 IC? What does the "T" in there mean??</TD></TR></TABLE>
You can use the 74hct373s with no problem.
Old Oct 1, 2003 | 06:47 PM
  #390
T-RO's Avatar
Yeah, I also had a problem when I burned a chip with the ERMbase P28. I havent had a chance to check if it was my connections though. Mabye next week...
Old Oct 1, 2003 | 07:04 PM
  #391
red_sir's Avatar
Default Re: (T-RO)
I need some help guys. =P
https://honda-tech.com/zerothread?id=636088
Old Oct 2, 2003 | 02:40 AM
  #392
rjardy's Avatar
Default Re: (red_sir)
So I am going to have to run the older version on my lap top becasue with the new software, I dont have full acces to the entire map area. Looking at both versions, there are some differences. For anyone running the older software, what should I know about it, to include setup. Or has anyone heard from blake about the version with scroll bars? That would be best, because I am allready familiar with this version. Thanks allot for the help guys.
Robert
Old Oct 2, 2003 | 05:38 AM
  #393
S-FLY's Avatar
I've also been following this program as well as a few others. I'll have a moded p28 running my turboed LS EK.
Can anyone tell me why uberdata doesn't support ECU control roms?
Stan
Old Oct 2, 2003 | 09:04 AM
  #394
Mr. Softee's Avatar
Default Re: (S-FLY)
why would you run a p28 w/ your ls?
Old Oct 2, 2003 | 11:33 AM
  #395
FyReo3's Avatar
Did I read somewhere that someone is going to host a site for Uberdata roms?
It would be pretty cool to be able to compare different roms based upon different setups.
I will be happy to contribute.
Old Oct 2, 2003 | 11:56 AM
  #396
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FyReo3 &raquo;</TD></TR><TR><TD CLASS="quote">Did I read somewhere that someone is going to host a site for Uberdata roms?
I will be happy to contribute.</TD></TR></TABLE>
http://www.b94cast.com/uberdata/ is the link. The site I'm developing, I'll try and find my own host for, so that I can update the BIN listings more easily.
I just got my ZIF sockets in today The ECU I'm picking up on Friday (P06) for $70 USD... then I just need the Atmel chips, a distributor, O2 sensor and the wiring harness plugs
Uberdata is coming... I'm so hyped!
Old Oct 2, 2003 | 11:57 AM
  #397
Mr. Softee's Avatar
Default Re: (raene)
ill share my tuned 255whp LS bin file @ 10psi
sam
Old Oct 2, 2003 | 12:24 PM
  #398
dabrown's Avatar
It would help if more than one site has maps. Otherwise your bandwith will kill you after everyone gets a hold of the links.
Old Oct 2, 2003 | 12:27 PM
  #399
Mr. Softee's Avatar
Default Re: (dabrown)
i can host it need be i have unlimted band width / space
sam
Old Oct 2, 2003 | 02:37 PM
  #400
dabrown's Avatar
Perfect.. Now if anyone else has any tuned bin's that would help..
