new version of uberdata
Old Dec 8, 2003 | 02:34 PM
  #126
Mr. Softee's Avatar
Default Re: (falconGSR)
lol sorry bro, just playing
Old Dec 8, 2003 | 02:38 PM
  #127
falcongsr's Avatar
What is this crap?
Default Re: (94goldjungsr)
its cool i just dont have the time to goof @ work.
Old Dec 8, 2003 | 02:43 PM
  #128
AROD's Avatar
Why doesn't blake and all his crew of workers make a softwear program with built ,help files, instructions........ect.. and send a demo out and if its the "HOT ****" everyone just buys a good version like a custom 9.0version, and more people would pay for it.
Old Dec 8, 2003 | 03:16 PM
  #129
Buraku's Avatar
Default Re: (1.83Tc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.83Tc &raquo;</TD></TR><TR><TD CLASS="quote">Why doesn't blake and all his crew of workers make a softwear program with built ,help files, instructions........ect.. and send a demo out and if its the "HOT ****" everyone just buys a good version like a custom 9.0version, and more people would pay for it.</TD></TR></TABLE>
Crew of workers? I work alone... goldjungsr is just there for sexual pleasure.
Old Dec 8, 2003 | 03:32 PM
  #130
Mr. Softee's Avatar
Default Re: (Buraku)
LOL! wtf!
Old Dec 8, 2003 | 03:37 PM
  #131
Distorted's Avatar
I'm sorting through the scripts and trying to learn this quick, one question i run into is in the new rev limits, its not specified as to which rev limits it controls. One is obviously for ftl but the speed engagement isnt written in as of yet. The other thing is with the Vtec, there are 4 vtec options. In theory dont you only need two, one for cross over on acceleration and one for cross over on deceleration? In misc options, does checking a box disable or enable. On one it specifically says disable, the others seem to be a guess and test, hehe.
Old Dec 8, 2003 | 03:42 PM
  #132
AROD's Avatar
ill pay you for a 3bar 9.0 version ill pay up to 250 for it , unless im blown away by the program then ill give you $400...........
Old Dec 8, 2003 | 04:44 PM
  #133
Buraku's Avatar
Default Re: (Distorted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Distorted &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorting through the scripts and trying to learn this quick, one question i run into is in the new rev limits, its not specified as to which rev limits it controls. One is obviously for ftl but the speed engagement isnt written in as of yet. The other thing is with the Vtec, there are 4 vtec options. In theory dont you only need two, one for cross over on acceleration and one for cross over on deceleration? In misc options, does checking a box disable or enable. On one it specifically says disable, the others seem to be a guess and test, hehe.
The rev limits are regular rev limits, no FTL. I removed FTL. Will add it back later. The ecu has 2 different rev limits, they both appear to be the same tho? I believe 1 of them is cold engine rev limit, and the other is warm. The 1st set is warm I believe.
There are also 2 sets of vtec points (4 total). I htink the other is part throttle vtec, some guy bitched that I didnt let them edit this in the eitor so i kno allow you to edit both.
In misc, a check means enabled unless otherwise noted. You dont want to check the o2 heater disabling box cuz that will disable your o2 heater, only use htis when u are homo like falcon and have a wideband that doesnt have a heater circuit on it Or if you're like me and short your o2 sensor on your downpipe frying your ecu's o2 heater circuits causing a cel
1.83Tc: plz doante some mansex to joseph instead, he is feeling lonely with todd at his house because they just cant be open with their feelings with each other
Old Dec 8, 2003 | 05:16 PM
  #134
Distorted's Avatar
Ah, that makes sense now. Wierd people. Well, i look forward to the ftl. I'm trying to pick up the basics of scripting while im studying for finals here.
Old Dec 8, 2003 | 06:29 PM
  #135
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">In misc, a check means enabled unless otherwise noted. You dont want to check the o2 heater disabling box cuz that will disable your o2 heater, only use htis when u are homo like falcon and have a wideband that doesnt have a heater circuit on it Or if you're like me and short your o2 sensor on your downpipe frying your ecu's o2 heater circuits causing a cel
oh you **** up your car and i am the homo? and for the record the wideband has its own heater controller circuit so the stock one was useless.
go stick your thumb up your butt.
no wait, dont, you'll probly like it.
Old Dec 8, 2003 | 09:37 PM
  #136
Mr. Softee's Avatar
falcon, dont make me post the convo
Old Dec 9, 2003 | 01:43 AM
  #137
bigwig's Avatar
Crew of workers? I work alone... goldjungsr is just there for sexual pleasure.</TD></TR></TABLE>
what happened to being incognito?
does the rev limits look funny on anyone elses computer?
Modified by bigwig at 4:09 AM 12/9/2003
Old Dec 9, 2003 | 10:29 AM
  #138
psychotic_z's Avatar
Default Re: new version of uberdata (Buraku)
Hey, quick question guys, what if I used a SAFC along with an Uberchip to tune out a little fuel. This was the plan until it hit me a few minutes ago - Would the using the SAFC to lower the MAP voltage 1-4% w/my 450cc injectors cause the Uber to throw incorrect timing or fuel? I just want to make sure -
Zach
Old Dec 9, 2003 | 10:40 AM
  #139
SleepyEG's Avatar
Default Re: new version of uberdata (psychotic_z)
why use the AFC when you could do the same thing, better, with uberdata?
Old Dec 9, 2003 | 11:37 AM
  #140
89civic1.8T's Avatar
Default Re: new version of uberdata (SleepyEG)
I like the idea of fine tunning with an AFC/VAFC and uberdata. You can make changes with the AFC with just a few pushes of a button.
Old Dec 9, 2003 | 11:49 AM
  #141
Default Re: new version of uberdata (89civic1.8T)
Yeah, that's the idea. For now, I'm burner-less and I can't make any changes to the chip Uber made for me a while ago, so until then I suppose running an AFC could fix out the rough spots. When I get a burner, I'll just burn the AFC changes and wallah! New chip.
If anything, tuning our chip setups with AFC and then burning an update would be faster than burn, plug in car, test, remove from car, guess changes, reburn, rinse and repeat.
Old Dec 9, 2003 | 12:13 PM
  #142
bigwig's Avatar
i wouldnt put it past blake for him to have uberdata able to do on the fly tuning since turboedit has it.......unless blake likes getting shown up
Old Dec 9, 2003 | 12:29 PM
  #143
Del_Slowest's Avatar
Default Re: (bigwig)
Those be fightin' words mister. I expect the next version of it will have auto tune capabilities. He's been hinting at in on the opening pages of the user agreement
Old Dec 9, 2003 | 12:43 PM
  #144
bigwig's Avatar
I'm hoping for auto tune capiblities and data logging using the stock 02 sensor. It would be super nifty if someone figured out how to replace the stock sensor with a better one and get super good datalogging results. No more wideband.......that would be jesus like...or should i say Blake like
Old Dec 9, 2003 | 02:42 PM
  #145
Buraku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic_z &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, that's the idea. For now, I'm burner-less and I can't make any changes to the chip Uber made for me a while ago, so until then I suppose running an AFC could fix out the rough spots. When I get a burner, I'll just burn the AFC changes and wallah! New chip.
If anything, tuning our chip setups with AFC and then burning an update would be faster than burn, plug in car, test, remove from car, guess changes, reburn, rinse and repeat.</TD></TR></TABLE>
Whats up man, you were the 2nd person to buy a chip from me! I remember you well. email me @ uberteg@tampabay.rr.com and I will hook you up with a cheap burner.
heres some more scripts for yall!
http://vertigo.webhostme.com/fuelmod_scripts.zip
bigwig: you can call me buraku-sama
Old Dec 9, 2003 | 03:00 PM
  #146
TeStUdO's Avatar
Whats up man, you were the 2nd person to buy a chip from me! :
What # was I????
Old Dec 9, 2003 | 03:31 PM
  #147
Buraku's Avatar
Default Re: new version of uberdata (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
What # was I????</TD></TR></TABLE>
Far far down, i only remembered him cuz I remembered his name and cuz he payed jon@thedropshop and i mailed it.
Old Dec 10, 2003 | 03:40 AM
  #148
ndogg's Avatar
hey Buraka, can you let us know how the assemble() function works? i would like to write a script but i am unsure of the exact syntax to use in my asm file. or should i just use a bunch of writebyte/writeword and assemble by hand?
also, when you defined disableCRC() again in the fuel script, are both of them run when called in open() in the main autoexec file?
**after more time... it looks like yes to me**
one more thing... why is it necessary to assemble the asm files the way you did? why can't you assemble them in the open() funtion of a particular script?
**after more time... so you don't assemble and write over your already saved data when you reopen it**
Modified by ndogg at 5:06 AM 12/10/2003
Modified by ndogg at 7:16 AM 12/10/2003
Old Dec 10, 2003 | 06:33 AM
  #149
Buraku's Avatar
Default Re: new version of uberdata (ndogg)
assemble("filename", 0ffset_in_rom_to_assemble_to);
when you call a function, it calls ALL instances of that function SO ifthere are 2 DisableCRC() fiunctions, both fo them get called when DisableCRC is called.
Old Dec 10, 2003 | 08:09 AM
  #150
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">assemble("filename", 0ffset_in_rom_to_assemble_to);</TD></TR></TABLE>
i mean what sytax in the assembly file?
like...
JBS 11.2, 02323h ;
or..
JBS off(00211h).2, somePlace ;
do you have the instruction set that your assembler looks for in a list or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">when you call a function, it calls ALL instances of that function SO ifthere are 2 DisableCRC() fiunctions, both fo them get called when DisableCRC is called.</TD></TR></TABLE>
cool
falcon or anyone... what is the best pin to use for a fts code? i tried using B8 but it seems as if the wiki is wrong because that didn't work.
btw... where can i host my scripts?
