new version of uberdata
Old Dec 11, 2003 | 02:26 PM
  #176
T-RO's Avatar
Default Re: (Buraku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">I am going to redo the main program interface, are there any suggestions to make it more appealing?</TD></TR></TABLE>
Yes, working scroll bars for us poor meeps that have crappy computers.
Old Dec 11, 2003 | 03:50 PM
  #177
Buraku's Avatar
Default Re: (T-RO)
i already fixed the scrollbars
The new version is on gimpy accord's site
Old Dec 11, 2003 | 04:15 PM
  #178
baphomet's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">
make sure you use it with the VERY newest version. ie 1.6.2 in the original 1.6, the autoexec file is different and some of my constants get defined 2wice, this is probably causeing the crash.</TD></TR></TABLE>
It worked on the previous ver. (1.6) but 1.61 gives a nasty crash - takes down everything, I can't even logout. I have not looked into it yet.
Old Dec 11, 2003 | 04:22 PM
  #179
Buraku's Avatar
Default Re: (slashDEVslashNULL)
you have to have a new autoexec file or it will do it, did he include it in the zip?
Old Dec 11, 2003 | 04:23 PM
  #180
Buraku's Avatar
Default Re: (bigwig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">in general are people seeing the IGN HI values weird? </TD></TR></TABLE>
this is 1 of the things fixed in 1.61
Old Dec 11, 2003 | 04:24 PM
  #181
jamlmm69's Avatar
Default need help how much boost
have a 92 civic w/ b16a2 i want to run high boost but how much can i run
and if not what do i need to do to run high boost i want around 400-450hp
can i do it what do i need
Old Dec 11, 2003 | 04:26 PM
  #182
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">you have to have a new autoexec file or it will do it, did he include it in the zip?</TD></TR></TABLE>No, but I copied the one that worked for the previous version over, with the same results.
Old Dec 11, 2003 | 04:27 PM
  #183
baphomet's Avatar
Default Re: need help how much boost (jamlmm69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamlmm69 &raquo;</TD></TR><TR><TD CLASS="quote">have a 92 civic w/ b16a2 i want to run high boost but how much can i run
can i do it what do i need </TD></TR></TABLE>
WTF
Old Dec 11, 2003 | 04:32 PM
  #184
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">i already fixed the scrollbars
The new version is on gimpy accord's site</TD></TR></TABLE>
This is the version I tried ndogg's script with this afternoon unless it's changed by then of course!
Old Dec 11, 2003 | 04:58 PM
  #185
TeStUdO's Avatar
Bump for the 3 bar and maybe another cool pic
Old Dec 11, 2003 | 05:07 PM
  #186
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">No, but I copied the one that worked for the previous version over, with the same results.</TD></TR></TABLE>
i really don't know what the hell you guys are doing to crash this. i am TRYING to crash mine and i can't. copy the files into the 1.61 and it will work without a problem.
Old Dec 11, 2003 | 05:11 PM
  #187
baphomet's Avatar
Default Re: (ndogg)
i really don't know what the hell you guys are doing to crash this. i am TRYING to crash mine and i can't. copy the files into the 1.61 and it will work without a problem.</TD></TR></TABLE>
Odd. To clarify, unzip 1.61 and unzip myftl.zip into same folder and it works for you? Or did you copy a different autoexec, and any other files?
BTW, I am on XP pro (at least I am running uberdata on XP, posting on LINUX )
Old Dec 11, 2003 | 05:14 PM
  #188
ndogg's Avatar
maybee the file was corupt or something. try the new version:
http://www.pgmfi.org/phorum/do...k.zip
i did like buraka said and added a check if there is no check in the box, none of my code will get run (no FTS or FTL) and the AC button wont do ****.
just unzip the 1.61. then unzip my **** and copy the files into uber1.61 folder
im on xp pro also
Old Dec 11, 2003 | 05:18 PM
  #189
baphomet's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">maybee the file was corupt or something. try the new version:
im on xp pro also</TD></TR></TABLE>
k - works, now to copy the misc scrips over.
Old Dec 11, 2003 | 05:21 PM
  #190
ndogg's Avatar
cool. as far as my logic and **** is concerned, i know that the progam will work. the only thing i'm unsure of is pin B8 and where/what it does in RAM. according to the wiki, my code will work, but i believe that the wiki could be wrong.
Old Dec 11, 2003 | 05:22 PM
  #191
baphomet's Avatar
okay, I copied these files over and one must have did it in.
rev.als.txt
tpsfuel.asm
boostcode.asm
coldfuel.asm
fuelmod.als.txt
mainfuel.asm
misc.als.txt
Old Dec 11, 2003 | 05:35 PM
  #192
baphomet's Avatar
okay I unziped in this order: overwriting anything old
1.61
myftl
new scripts
rev.als
fuelmod
all is good then copied gimpy accords scripts over and it crashes
Old Dec 11, 2003 | 05:38 PM
  #193
Buraku's Avatar
i uploaded an updated version of 1.61, it times out some of the infinte loop/crashing problems (only a concern with bad scripts, heh). Also fixed a misc scrollbar bug that made u have to resize the window b4 the scrollbars would show up.
And dont use fuelmod.als.txt
Old Dec 11, 2003 | 05:48 PM
  #194
baphomet's Avatar
And dont use fuelmod.als.txt</TD></TR></TABLE>
that did it
Old Dec 11, 2003 | 06:53 PM
  #195
PHiZ's Avatar
that did it </TD></TR></TABLE>
I'd expect as much from a linux user
-PHiZ
Old Dec 11, 2003 | 06:55 PM
  #196
bigwig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">i uploaded an updated version of 1.61, it times out some of the infinte loop/crashing problems (only a concern with bad scripts, heh). Also fixed a misc scrollbar bug that made u have to resize the window b4 the scrollbars would show up.
Um...where is the updated version...in the zip or under the scripts? i tried both and i had to resize the window for A scroll bar to come up. I'm not sure if its supposed to have one controlling the Y axis, but i only get one controlling the X axis. Just thought i should bring it up
Old Dec 11, 2003 | 06:58 PM
  #197
baphomet's Avatar
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
If I had hardware that was OPENbsd compatible...........then again, maybe I should git wit you FREEbsd guys What do you mean anyway, punk?
Old Dec 11, 2003 | 06:59 PM
  #198
Buraku's Avatar
i didnt feel like adding a y-axis scroll bar. and redownload the same 1.61 zip file, its updated
Old Dec 11, 2003 | 07:03 PM
  #199
bigwig's Avatar
gotcha
I downloaded it again...i still need to resize my window for the scroll bars to come up. Just letting you know.
Old Dec 11, 2003 | 07:07 PM
  #200
Buraku's Avatar
ok, then **** scroll bars and cheap bastards with 800x600 moniters.
