new version of uberdata
Old Feb 12, 2004 | 08:46 AM
  #651
Del_Slowest's Avatar
Default Re: (slofu)
I'm looking to buy some 27c256 chips. If anybody is upgrading to the 29c256 chips then tell me and i'll paypal a lil cash for your 27's. Thanks
Old Feb 12, 2004 | 11:57 AM
  #652
Joseph Davis's Avatar
Default Re: (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">can you chip a jdm p72 auto ecu for uberdata (and for a manual tranny)?</TD></TR></TABLE>
Interesting question, I've never seen such a beast. If you can provide a scan of the top of the motherboard with all the serial numbers and such, I should be able to tell you. If it is like the other JDM ECUs of that year, you have to buy a SMT 74HC373xx... the exact PN is on PGMFI somewhere.
Old Feb 12, 2004 | 04:04 PM
  #653
slofu's Avatar
Default Re: (J. Davis)
cool. i'll take a look. i thought that i remembered someone (maybe falcongsr?) saying that they'd done it (or something like it) before.
Old Feb 12, 2004 | 04:29 PM
  #654
MADEINIRAQ's Avatar
Default Re: (slofu)
somebody on the uberdata forum is running a jdm p72.. he said it was easier to chip than usdm ecu.
i don't know though
Old Feb 12, 2004 | 08:10 PM
  #655
ID_ten_T's Avatar
i just wanna confirm, the chip below will work, correct? thanks.
27C256 32K Eprom CMOS 12.5V
Old Feb 12, 2004 | 11:24 PM
  #656
Default Re: (ID_ten_T)
27Cxxx(N) and 29Cxxx(N) work perfectly.
The "N" means normal or some such... if you have a through-hole pin to solder, aka 28 DIP, aka 28 pin Dual Inline Package, it is the correct chip. If it doesn't have a suffix it is implied, then it's the same thing as the "N"
Just to overexplain the subject, and make a short story real long.
Old Feb 19, 2004 | 11:49 PM
  #657
1bar's Avatar
Ive been looking over uberdata for awhile now and its awesome Just had a few quesitons.
With uberdata are you able to keep the ecu in open loop? Is this o2 Heater disable under misc?
What is up with Map Scalar? And why would anyone ever rewrite this?
And the p28 bins are kinda confusing. Whats up with the eratic rpm?
thanks and excuse me if these quesiton have already been aswered
Old Feb 20, 2004 | 12:30 AM
  #658
genop's Avatar
Default Re: (1bar)
you must first open the stockgsr.bin file, after you do that you go to import and select import p28 and then find the p28 file you want to use and import it. The reason for this is that uberdata was based on p72 code.....thats why your map looks really funky.
Old Feb 20, 2004 | 08:03 AM
  #659
Cyphear's Avatar
Default Re: (1bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar &raquo;</TD></TR><TR><TD CLASS="quote">With uberdata are you able to keep the ecu in open loop? Is this o2 Heater disable under misc?
There isn't an open loop option. Heater disable is included under misc. You would change your map scalar if you wanted more "definition" in your boost coloums. I personally am not going to change it, but you could fine tune better if you changed a vacum colum to a boost column.
Old Feb 20, 2004 | 09:25 AM
  #660
b18b1hmtlove's Avatar
http://WWW.ECIMULTI.ORG/UBERDATA
Old Feb 20, 2004 | 09:50 AM
  #661
1bar's Avatar
Default Re: (b18b1hmtlove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">http://WWW.ECIMULTI.ORG/UBERDATA</TD></TR></TABLE>
thanks
Old Feb 23, 2004 | 06:36 AM
  #662
ID_ten_T's Avatar
Default Re: (1bar)
newb question about datalogging --
what information does the ecu transmit when datalogging? i know that it doesnt output a wideband o2 signal and it is difficult/impossible to tune using a narrowband signal. so other than rpm, what else does datalogging the ecu tell us? i am just trying to figure out if it is worth the trouble. thanks.
Old Feb 23, 2004 | 01:10 PM
  #663
sensor readings and throttle positions....blah blah blah. Look on the uberdata forum, it has a list.
Old Feb 26, 2004 | 03:27 PM
  #664
warwagon's Avatar
call me stupid but your stock map sensor will read 10lbs and the uberdata will be fine using that
or if i wire in a gm 3 bar i will be fine with that with the uberdata
Old Feb 26, 2004 | 04:04 PM
  #665
Cyphear's Avatar
Default Re: (warwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">call me stupid but your stock map sensor will read 10lbs and the uberdata will be fine using that
or if i wire in a gm 3 bar i will be fine with that with the uberdata</TD></TR></TABLE>
Yeah, theres a place where you specify what map sensor you have.
Old Feb 26, 2004 | 04:58 PM
  #666
I cant say it enough. please refer all your questions to http://www.ecimulti.org/uberdata. this thread should just die.
and yes, you can run 10psi on a stock map sensor.
Old Feb 26, 2004 | 05:39 PM
  #667
warwagon's Avatar
yes i have the software just making sure that the map sensor part was functional thank you bye bye
Old Feb 26, 2004 | 07:11 PM
  #668
there is something else on that site. its called an uberdata support forum. i figured most people would notice that since i keep sending people to the site for that purpose.
Old Feb 26, 2004 | 07:40 PM
  #669
Cyphear's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">yes i have the software just making sure that the map sensor part was functional thank you bye bye</TD></TR></TABLE>
Bye.
That uberdata forums is the place to go to get good responses on uberdata specific questions. Everyone that wrote it is on there.
Old Jul 18, 2005 | 12:06 PM
  #670
ExVtec's Avatar
Default Re: new version of uberdata (ndogg)
None of the links work...whats teh deal?
  #671
ExVtec's Avatar
Old Jul 18, 2005 | 12:15 PM
  #672
dustin's Avatar
Default Re: new version of uberdata (ExVtec)
go to:
http://forum.pgmfi.org
Old Jul 18, 2005 | 12:21 PM
  #673
adseguy's Avatar
WOW! ....NEW VERSION OF UBERDATA 1.5!!!! **** I BETTER GET ON THIS!
dude this is sooooooo old. The new version is 1.92 here http://uberdata.pgmfi.org/forum
Old Jul 18, 2005 | 12:22 PM
  #674
dustin's Avatar
Default Re: new version of uberdata (adseguy)
it's a lot easier to read the pgmfi forum... that blue site is slow and hurts my eyes.
hehe.
Old Jul 21, 2005 | 06:15 AM
  #675
Urban Camo's Avatar
Default Re: new version of uberdata (dustin)
1.92? alls i see is 1.70? WTF?
JzDcM
Jul 26, 2006 10:06 PM
Ben Huynh
Jan 1, 2006 11:08 AM
nickromeo
Dec 31, 2005 11:42 PM
DR. ON POINT
Jul 25, 2002 07:50 PM
95LSVTEC
Oct 4, 2001 08:10 PM
