new version of uberdata
Old Dec 10, 2003 | 08:42 AM
  #151
bigwig's Avatar
get some webspace at angelfire.com....or pgmfi allows you to upload bins and **** like that...either or should work for those tiny txt files
PAGE 6 OWNAGE!
Old Dec 10, 2003 | 11:02 AM
  #152
B94Cast's Avatar
Default Re: new version of uberdata (ndogg)
I can host scripts for you or anyone here that needs a hosting location. Just let me know and I will post them for you.
Old Dec 10, 2003 | 11:06 AM
  #153
chidoks's Avatar
Default Re: new version of uberdata (B94Cast)
anybody running uberdata on an h22?? i've played around with the software on a b18c with a p72... i am going to be running the 3bar version on a p28 ecu controlling an h22 motor... Where do u get basemaps for the h22? Or do u just work with a basemap designed for a b18c?
Old Dec 10, 2003 | 12:06 PM
  #154
toxicshit's Avatar
what kind of assembler code is that ??
i know the inhell 8051 assembler code and want to read some info on the ASM code that your using so i can help a bit and try some **** for myself
trying to lear some right now but its 22:15 over here and ive been awake for over 16 hours so it wont go as quickly as normaly
@ /dev/null thnx for helping me with that b20 script !!!
@ buraku GREATH PROGRAMM i have posted info on PA ELD sensors enabling and disabling and speed limit settings for EDM and JDM purposes. who wants to help to make a bit more misc.asm.txt for the EDM / JDM people ( /dev/null ?? falcon ?? buraku ?? )
Greetz Erwin
p.s. sorry for my bad english.
Modified by toxicshit at 9:17 PM 12/10/2003
Old Dec 10, 2003 | 12:23 PM
  #155
falcongsr's Avatar
What is this crap?
Default Re: (toxicshit)
sorry i havent been contributing, my real job is owning me.
Old Dec 10, 2003 | 12:28 PM
  #156
Buraku's Avatar
gimpy accord made/modified a few scripts: http://www.ecimulti.org/uberdata
he did a great job! if you finish a script, email it to me @ uberteg@tampabay.rr.com and i will make sure uberdata users have access to it.
Modified by Buraku at 9:51 PM 12/10/2003
Old Dec 10, 2003 | 12:42 PM
  #157
toxicshit's Avatar
Default Re: (Buraku)
Modified by toxicshit at 10:14 PM 12/10 /2003
i see that my script issnt needed annymore GIMPY
Modified by toxicshit at 10:29 PM 12/10/2003
made a misc.als.txt for JDM bins with speedlimit from 112 mph to max 158mph. i emaild it to bukaru and i hope that he will host the file.
Greetz Erwin
Modified by toxicshit at 6:48 AM 12/11/2003
Old Dec 10, 2003 | 12:52 PM
  #158
Buraku's Avatar
that stuff was just added in gimpy's scripts :/ gimpy also fixed a rounding bug in the vtec crossover points
Old Dec 10, 2003 | 01:49 PM
  #159
bigwig's Avatar
gimpy=hmt.com obd1 pimp daddy...
not to mention his skills w/ dsm and gm i believe...
Old Dec 10, 2003 | 09:16 PM
  #160
ndogg's Avatar
[QUOTE=toxicshit]what kind of assembler code is that ??[QUOTE]
i have been using this for a reference:
http://pgmfi.org/resources/doc...l.pdf
Old Dec 10, 2003 | 09:53 PM
  #161
toxicshit's Avatar
Default Re: (ndogg)
ah yes i worked with this kind of MC way back i have a instruction manual laying around here have to jump into it again thnx for the quick info
Old Dec 11, 2003 | 03:44 AM
  #162
ndogg's Avatar
http://www.pgmfi.org/phorum/do...l.zip
check out my scripts. the misc.als.txt is a modified version of gimpy's. i added speed limit disable (not tested though). the fts one is a little different than you are used to. in my implimentation, when the AC button is pressed, then FTL is set. if ac is not pressed, you can burnout/do whatever. there is also FTS in there that requires you to wire up a clutch switch to B8 but i'm not sure if it works. please let me know.
i'm going to test this weekend but i have no car right now. NONE of this is tested, i just put it up encase you were bored and wanted to help
Old Dec 11, 2003 | 10:40 AM
  #163
bigwig's Avatar
Default Re: (ndogg)
in general are people seeing the IGN HI values weird?
Old Dec 11, 2003 | 10:49 AM
  #164
raene's Avatar
Default Re: (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">sorry i havent been contributing, my real job is owning me.
I'm still running 1.2, no time to play
ndogg's FTS teaser - that it could be done - is making me randy I will have to play with the code. I have a clutch switch and I can easily ghetto-rig to B8. I also don't have a/c so I'd love to rig a switch to enable FTL... dayum. This program keeps getting better and better I will probably start using 1.6 now... but ndogg, your script makes Uberdata crash (at least for me).
Modified by raene at 12:09 PM 12/11/2003
  #165
Buraku's Avatar
Default Re: (ndogg)
wow, nice ndogg. Add a checkbox to the FTL menu for disabling the use of the a/c button. WHen its checked, assemble a different assembly file That way people wont have to remove/add scripts constantly.
As soon as its tested and verified, I will include it in the main uberdata zip (i'm gonan change this to a install program soon). I am going to redo the main program interface, are there any suggestions to make it more appealing?
Old Dec 11, 2003 | 11:00 AM
  #166
DRP SHP TECH's Avatar
hey whats up man just wanted to ask u about the datalogging features
Old Dec 11, 2003 | 11:04 AM
  #167
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote"> am going to redo the main program interface, are there any suggestions to make it more appealing?</TD></TR></TABLE>
It's already functional beauty As long as everything works great I could care less how it looks.
More features I'd love to see on the interface: Drag-and-drop points on the 2d graphs - allow you to generally build an ignition or fuel curve and smooth the holes without toggling back and forth between grid and points. That might be too much to ask for, though Also, maybe put the VTEC engage and disengage on the maps as a visual placeholder. I'm also still waiting for the 3d graphs, but that's just eye candy I guess.
Some sort of meaningful # for the fuel maps would be good too. Not really sure what the #s stand for, yet.
What else... some sort of graphical compare-map feature. It's sometimes hard to find changes between tunes unless you keep a changelog. Having Uberdata manage this would be nice - and even better, have it create a .txt file and store notes on the tune. So you can easily reference tunes and refer back to them, then compare them on-the-fly without opening multiple Uberdata windows. Adding a textbox for a changelog and assigning dependencies to a file shouldn't be too hard
Man I love this program... so glad I donated... *tear-jerking moment*
Old Dec 11, 2003 | 11:14 AM
  #168
bigwig's Avatar
um...let you be able to fill in given numerical values in the box....
Working scroll bars......
when you leave your mouse over something it has one of those lil yellow boxes come over it and say what it is briefly....
allow me to press "**** you" and still you use your damn program
um...honestly the scroll bars and the lil boxes telling you what everything is is all i care about....id rather time be spent on datalogging, on the fly tuning, and support to atleast 1 bar.
i guess i have to donate if i start making requests......
Old Dec 11, 2003 | 01:44 PM
  #169
PHiZ's Avatar
Default Re: (bigwig)
Buraku needs a GM 3bar map sensor. This will directly benefit everyone.
MAP sensor from:
1989 3.8L V6 turbo trans-am
GM part number:
-Old: 16040749
-Old plug: ?
-New: 12223861
-New plug: 15305891
AC-DELCO part number (autozone/pepboys/advanced auto)
MAP sensor: 213-101
Plugs:
company: Conduct-Tite
P/N:85115
or
same company "GM Throttle Position Sensor Harness"
This would be a worthy donation, if anyone works at an auto-parts store, or has a friend that does, or has a spare 3bar map lieing around, please contact buraku.
-PHiZ
Old Dec 11, 2003 | 01:51 PM
  #170
bigwig's Avatar
here is a dumbass question....if we want to run over 10.38psi...we need the 3 bar map sensor right? and how much is one?
im going to for you guys
Old Dec 11, 2003 | 02:00 PM
  #171
b18bturbo's Avatar
3bar map sensor with ac harness is around 60-70 bucks complete .. gmpartsdirect.com get the map from there and autozone/pepboys get the wiring harness
Old Dec 11, 2003 | 02:04 PM
  #172
ndogg's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">... but ndogg, your script makes Uberdata crash (at least for me).Modified by raene at 12:09 PM 12/11/2003</TD></TR></TABLE>
make sure you use it with the VERY newest version. ie 1.6.2 in the original 1.6, the autoexec file is different and some of my constants get defined 2wice, this is probably causeing the crash.
Old Dec 11, 2003 | 02:10 PM
  #173
pbomers's Avatar
Default Re: (ndogg)
Guys I've got a hook up at Napa Autoparts. Let me see what I can come up with for prices, but I might be able to donate a 3 bar and harness.
Thanks
-Paul
Old Dec 11, 2003 | 02:14 PM
  #174
Buraku's Avatar
Default Re: (TinyCRX)
i already have the harness, i got scammed on a 3bar (they sent me non-voltage based)
Old Dec 11, 2003 | 02:18 PM
  #175
pbomers's Avatar
if you can find it on napa's website i can probably get it 1/2 price.
i'd be willing to donate it, but i want to make sure i send you the right part.
-Paul
