new version of uberdata
Old Jan 5, 2004 | 11:09 AM
  #526
VTC_CiViC's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">
It uses a 12v source so would that work? Splicing up a cig lighter end to a power cord?
That easy? I know it's 12v but do they regulate different ampergaes or are all plugs the same?
Old Jan 5, 2004 | 11:37 AM
  #527
T-RO's Avatar
Default Re: (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">
That easy? I know it's 12v but do they regulate different ampergaes or are all plugs the same?</TD></TR></TABLE>
Beats me, i'll post a message on http://www.willem.org and see what they say. They have a message forum too.
Old Jan 5, 2004 | 11:46 AM
  #528
Mad Cow's Avatar
Default Re: (T-RO)
Anyone have a problem with throwing a TPS code? (CEL 7)I seem to get it when I boost for more than 2 seconds or so...
Has anyone else had this code (or any other random ones)? Was fine before Uberdata, and I've tried two TPS's, both do the same thing... Any ideas?
Modified by MadCow at 4:06 PM 1/5/2004
Old Jan 5, 2004 | 12:17 PM
  #529
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote"> Also, I wish I had a cigarette lighter style power source for my Willem burner so I didn't have to come back home to burn chips. It'd be nice to hit the street with my laptop, ROM burner and wideband (once I got it) and do the tuning in one shot. </TD></TR></TABLE>
I am living your dream - Batronix USB burner, draws power from the laptop's USB port
Old Jan 5, 2004 | 12:23 PM
  #530
Quade's Avatar
Default Re: (slashDEVslashNULL)
Just wire it up to your ignition dude.
Old Jan 5, 2004 | 12:24 PM
  #531
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">
I am living your dream - Batronix USB burner, draws power from the laptop's USB port </TD></TR></TABLE>
I was so tempted last week when I was ordering mine, but the $200(+$25 or so shipping) just scared me shitless...LOL settled for the Programmer 4 instead, but it shoud be nice still...just gotta install a power inverter in the ride maybe.
Old Jan 5, 2004 | 12:44 PM
  #532
baphomet's Avatar
Default Re: (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">
just gotta install a power inverter in the ride maybe. </TD></TR></TABLE>
They are $30 at rat hack.
Old Jan 5, 2004 | 02:27 PM
  #533
VTC_CiViC's Avatar
Haha, you suck!
Old Jan 5, 2004 | 06:55 PM
  #534
cornhusker's Avatar
Default Re: (billab2ong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billab2ong &raquo;</TD></TR><TR><TD CLASS="quote">are we sayin that at this point 1.2 is the better version to run at the moment?</TD></TR></TABLE>
with all this talk of 1.2, where can we find it? i checked ecimulti.org, but i dont have access to 1.2 or 1.5.
Old Jan 5, 2004 | 07:11 PM
  #535
ID_ten_T's Avatar
Default Re: (cornhusker)
i'm new to all this, so please bear with me, thanks
well all my eprommer and 29c256 came in today, so i wanna get diy tuning. quick question though, since uberdata is based on the p74/p72 platform, if burn a rom using uberdata and use it in a chipped p28, will i have a CEL? i read that i will have to disable the knock sensor, is this true? is there anything else? thanks in advance.
Old Jan 5, 2004 | 07:36 PM
  #536
raene's Avatar
Default Re: (ID_ten_T)
Yes, disable the knock sensor. Do a search on http://www.pgmfi.org and look in the Wiki for more information on how to do that.
Or http://www.nitroburn.com/pgmfiwiki/index.php/P28
Old Jan 5, 2004 | 08:20 PM
  #537
cinq's Avatar
It's not too late for anyone else that is interested in the Batronix USB burner. I'll be ordering them tomorrow, and we have enough people to get the nice deal.
https://honda-tech.com/zero...40472
Price is $213.55 shipped. Lemme know guys. Tomorrow is the dead line.
Old Jan 5, 2004 | 08:22 PM
  #538
baphomet's Avatar
Default Re: (cinq)
I want a group buy on the romulator.
Old Jan 5, 2004 | 08:26 PM
  #539
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">I want a group buy on the romulator.</TD></TR></TABLE>
Definently!!!!
Old Jan 6, 2004 | 12:40 AM
  #540
swlabhot's Avatar
Yes that would be nice to have indeed.
Old Jan 6, 2004 | 12:42 AM
  #541
swlabhot's Avatar
It will only draw the current that it needs. Just put an inline fuse in (amp rating according to what the unit requires) and you should be good to go.
Old Jan 6, 2004 | 12:45 AM
  #542
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Something interesting of note while driving the car last night on Uberdata again, whenever the car would see greater than 500 mm/Hg vacuum (very low throttle), the A/F gauge would stay pegged on the rich end, but with less than 500 mm/Hg (more throttle) and closer to atmospheric, the A/F would cycle back and forth as the car should during closed loop. I do get the feeling this is somehow tied to the TPS, almost as if when it's too low the ECU just assumes you're at 0 TPS and holds the injectors at an idle position.. not 100% sure about this but that's my guess for now
Either way, she idles fine and runs VERY hard in boost with a base (rich) map and only .65 degrees-per-psi retard </TD></TR></TABLE>
It sounds like you are using the Autometer AF gauge (or similar) to check the AFR?? Please tell me are not!!??
Old Jan 6, 2004 | 05:15 AM
  #543
GimpyAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cornhusker &raquo;</TD></TR><TR><TD CLASS="quote">
with all this talk of 1.2, where can we find it? i checked ecimulti.org, but i dont have access to 1.2 or 1.5. </TD></TR></TABLE>
Umm... its there
http://www.ecimulti.org/uberdata/downloads/app/
click on Archive and then the version you want
Old Jan 6, 2004 | 05:54 AM
  #544
VTC_CiViC's Avatar
Default Re: (swlabhot)
I'm not checking A/F, i'm only using the Autometer to reference when/if the car cycles through open/closed loop.
Old Jan 6, 2004 | 08:45 AM
  #545
cinq's Avatar
You want discounts on them? We could...I just called the company up...and if we can get 10 people...Retail price is $179.95 but the price will be $145.46 for us(that's 20% off retail) each + 3%? paypal fees since you guys will be sending the money to me to order them....this is for the Pocket Romulator. Lemme know how many are interested.
Note: Less than 10 people but more than 4 will get 15% off the retail price.
Here is the website...anyone want to start a groupbuy is fine by me. Just as long as we all get them for cheap.
http://xtronics.com/memory/romutator.htm
Modified by cinq at 1:11 PM 1/6/2004
Modified by cinq at 3:37 PM 1/6/2004
Old Jan 6, 2004 | 08:49 AM
  #546
DA-MAX's Avatar
Default Re: (cinq)
hell yeah I'd be in if yall can stretch it until next week
Old Jan 6, 2004 | 08:59 AM
  #547
TurboJesse
Guest
Posts: n/a
Default Re: (cinq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cinq &raquo;</TD></TR><TR><TD CLASS="quote">
You really want a groupbuy on that? We could...I just called the company up...and if we can get 10 people...the price will be $145.46 (that's 20% off retail) each + 3%? paypal fees since you guys will be sending the money to me to order them....this is for the Pocket Romulator...same one hondata is selling. Lemme know how many are interested.
Im down Has anyone successfully used that romulater with uberdata yet? Will it work with v1.3?
Old Jan 6, 2004 | 09:04 AM
  #548
billab2ong
Guest
Posts: n/a
what exactly is the point of the romulator w/ uberdata? is it for on the fly tuning?
Old Jan 6, 2004 | 09:08 AM
  #549
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billab2ong &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is the point of the romulator w/ uberdata? is it for on the fly tuning?</TD></TR></TABLE>
essentially
Old Jan 6, 2004 | 09:29 AM
  #550
marlborocars's Avatar
To program on the fly? only if blake implement map trace in UBERDATA
