new version of uberdata
Old Dec 31, 2003 | 02:57 PM
  #476
DA-MAX's Avatar
Default Re: (raene)
thanks, exactly what I wanted to know!!!
Old Jan 1, 2004 | 08:36 AM
  #477
Quade's Avatar
Default Re: (DA-MAX)
Happy New Year to all at Hondatech.
Old Jan 1, 2004 | 08:56 AM
  #478
toxicshit's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
That's what I think, for the reasons I stated in my earlier post... that it should be OK if you lower compression with the same timing adjustment, but if you up the compression, pull timing. Personally I wouldn't boost until you get it tuned with the new compression anyway, so for getting from the shop to the tuners' you should be fine driving it.
</TD></TR></TABLE> Thnx for clearing that up now i can drive with a good feeling about it from the shop to the tuner...
That's the idea behind Hondata boost cut, is it not? Very, VERY valuable idea... </TD></TR></TABLE> Yes i would like to see that. i would just cut ignition and not the fule. Quade Ask Buraku wich free FFFFF's you can ust for the saving of your max boost level!! so you dont place it somewhere where he uses something : Blake wich adresses are free for scripting purposes. i think he will just need 2 byte or 4 byte so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">Happy New Year to all at Hondatech.
</TD></TR></TABLE> Happy new year to all on this board !!
@ Quade dont forget so set a enable boost cut and a disable boostcut checkbox. and maybe set the MAX boostlevel and automaticly resume normal functions 1 or 2 PSI below boost cut to keep it from going on/off on/off ( Sorry for my bad english )
Old Jan 1, 2004 | 11:36 AM
  #479
Quade's Avatar
Default Re: (toxicshit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit &raquo;</TD></TR><TR><TD CLASS="quote"> Quade dont forget so set a enable boost cut and a disable boostcut checkbox. and maybe set the MAX boostlevel and automaticly resume normal functions 1 or 2 PSI below boost cut to keep it from going on/off on/off ( Sorry for my bad english )</TD></TR></TABLE>
I'm stumped. I figured I'll use code similar to rev limit but how do I set my max boost limit and tell it to cut ignition if it's over the limit? help anyone? Buraku?
Old Jan 1, 2004 | 11:53 AM
  #480
Mad Cow's Avatar
Default Re: (Quade)
I talked to Buraku about this the other day...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
[04:00PM] Me: what's he stoppin by for?
[04:03PM] Me: if im only boosting 7psi, you think its wise to richen up the last column to like 800 or so incase I spike?
[04:04PM] Buraku: spike to what?
[04:04PM] Me: well
[04:04PM] Me: i dunno, to whatever
[04:04PM] Buraku: 15psi? wont really matter
[04:04PM] Buraku: spike to 11? the mapo sensor can read it and will dump extra fuel anyways
[04:05PM] Me: what happens if it goes past the MAP limit?
[04:05PM] Buraku: map sensor stops reading above that
[04:05PM] Buraku: so it will read approx 4.7v at 15psi, and at 11psi
[04:05PM] Buraku: ecu thinks its at 11
[04:05PM] Buraku: run lean
[04:06PM] Me: well thats my point, if i put the last colum (11.03) at like 825 or so
[04:06PM] Me: then once it reads 11 (which it shouldnt, it would only do that in a spike)
[04:06PM] Me: it will dump lots of fuel
[04:06PM] Me: and not run lean
[04:06PM] Me: or as lean
[04:06PM] Buraku: yah u can do that
[04:07PM] Buraku: or u could just write a boost cut script
[04:07PM] Me: dont know any ASM heh
[04:07PM] Buraku: damn, ur fucked
[04:07PM] Buraku: i will write it b4 we chip your ecu then
[04:08PM] Me: how would you cut it? what would you do, just have it rev limit or something?
[04:08PM] Buraku: fuel cut
[04:08PM] Buraku: yah
[04:08PM] Buraku: ghetto way (easiest) is to lwoer the rev limit when u rich a set pressure
[04:09PM] Me: what's the safest way? wouldnt cuttin fuel be bad?
[04:09PM] Me: i guess not
[04:09PM] Me: couldnt you just retard timing hardcore?</TD></TR></TABLE>
Old Jan 2, 2004 | 06:14 AM
  #481
roadie_jay's Avatar
Has anyone posted .bin files for a p28 running a b16a? Raene mentioned that he had that setup, but I haven't seen any bin's mentioned in the thread or on the Uberdata site or Gimpy's. I'm running an NA b16a1 converted to OBD1 using a p28. I selling the VAFC that came in the car and buying a wideband and eprom burner to switch to Uberdata = total newbie.
Old Jan 2, 2004 | 08:13 AM
  #482
Mad Cow's Avatar
Default Re: (roadie_jay)
Just use stockgsr.bin and tune from there.
Old Jan 2, 2004 | 08:19 AM
  #483
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadie_jay &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone posted .bin files for a p28 running a b16a? Raene mentioned that he had that setup, but I haven't seen any bin's mentioned in the thread or on the Uberdata site or Gimpy's. I'm running an NA b16a1 converted to OBD1 using a p28. I selling the VAFC that came in the car and buying a wideband and eprom burner to switch to Uberdata = total newbie.</TD></TR></TABLE>
Import the p30 maps into the stockgsr.bin and BAM stock honda b16 maps, add boost etc and your set - tune from there.
Good luck!
Old Jan 2, 2004 | 09:59 AM
  #484
roadie_jay's Avatar
Thanks dev. When you say import the maps, does that mean that I copy and paste them in the editor? Go easy on me if thats a stupid question. I did notice that the new version has an import function, but the website warns that its not ready to use yet.
Thanks again for the help.
Jay
Old Jan 2, 2004 | 10:48 AM
  #485
raene's Avatar
I stated I'm using a B16, but I haven't been able to get 1.63 running without a solid CEL. Everything's great until I crank it, and it cranks, and cranks, and cranks... I think it's the JDMP72USDMB16base I'm using. I will be trying stockGSR today, and yes, AFAIK just cut and paste in the correct #s in all the cells.
My question is, what's fuel pressure on the del Sol VTEC vs on the Integra GSR? That will affect the pulsewidths given, I'd like to know the correct values and duplicate them on my own car...
Old Jan 2, 2004 | 11:28 AM
  #486
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadie_jay &raquo;</TD></TR><TR><TD CLASS="quote">Thanks dev. When you say import the maps, does that mean that I copy and paste them in the editor? Go easy on me if thats a stupid question. I did notice that the new version has an import function, but the website warns that its not ready to use yet.
Jay</TD></TR></TABLE>
Yeah I meant use the import feature, wait until the fixed one is posted. I made a p72 bin with b16 values in it and changed the scalars (I believe it is the one raene is using) but I have not tried it with 1.6x just 1.2. (And from the looks of it, it does not want to run on 1.63, from raene's experience) If you can't wait and don't feel like making your own bin, just use 1.2 until the import feature is fixed.
BTW, stock gsr should run fine, they are very close. I ran jdm b18c4 maps (long story) on my b16a2 and it ran fine.
Old Jan 2, 2004 | 12:13 PM
  #487
Civic TSI's Avatar
Default Re: (slashDEVslashNULL)
I've just gave a shot at 1.63 (never tried 1.2) on my P28. The engine fired like it was stock. I had a cell but I forgot to disable the knock sensor Now it's running with no cell, the rev limit works fine @ 2500 (just for testing). If it could stop snowing, I could have done a test drive Now where is that ZIF socket...
Old Jan 2, 2004 | 12:21 PM
  #488
baphomet's Avatar
Default Re: (Civic TSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic TSI &raquo;</TD></TR><TR><TD CLASS="quote">I've just gave a shot at 1.63 (never tried 1.2) on my P28. The engine fired like it was stock. I had a cell but I forgot to disable the knock sensor Now it's running with no cell, the rev limit works fine @ 2500 (just for testing). If it could stop snowing, I could have done a test drive Now where is that ZIF socket...</TD></TR></TABLE>
Old Jan 2, 2004 | 02:21 PM
  #489
toxicshit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic TSI &raquo;</TD></TR><TR><TD CLASS="quote">I've just gave a shot at 1.63 (never tried 1.2) on my P28. The engine fired like it was stock. I had a cell but I forgot to disable the knock sensor Now it's running with no cell, the rev limit works fine @ 2500 (just for testing). If it could stop snowing, I could have done a test drive Now where is that ZIF socket...</TD></TR></TABLE> Verry nice . What bin did you use ? disable that knock and give it a nice test when it stops snowing and have fun.
Old Jan 2, 2004 | 02:29 PM
  #490
cinq's Avatar
That's what we all waiting to hear..someone actually made a successful burn with the 1.6x. I hope more people with story like this can share...I'm waiting to get my burner..then I will be burning left and right. To Sir Blakes for making it possible...
Old Jan 2, 2004 | 03:51 PM
  #491
Civic TSI's Avatar
Default Re: (cinq)
I've used P28-ERMbaseline bin. BTW, is there any docs about the scripting commands and the syntax ? I was about to ask how Uberdata knew where to org the asm routines until I looked at a script, very nice. Now is it possible to get a memory map of the rom ?
BTW, what's the diff between 27SF256 and 29C256 chips ?
Old Jan 2, 2004 | 04:04 PM
  #492
swlabhot's Avatar
I believe the 27xx256 is write once and not rewritable and the 29c256 is an EEPROM which means you can rewrite as many times as you want on the same chip so get this one.
Old Jan 2, 2004 | 04:35 PM
  #493
raene's Avatar
Default Re: (swlabhot)
I believe you can get 27c256 that are rewriteable or ones that are single-writable. I'm looking at some 27c chips that we got for my brother's PW0 that I socketed and they're rewriteable They have to be UV-erased though.
/dev/null, thanks, I'll try stockGSR then I kinda sorta remembered that you used Crome to import the values into the usdmb16base bin so I figured something between Crome and Uberdata 1.63 was interfering whereas it worked fine with 1.2? I dunno.
Old Jan 2, 2004 | 04:46 PM
  #494
baphomet's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">I believe you can get 27c256 that are rewriteable or ones that are single-writable. I'm looking at some 27c chips that we got for my brother's PW0 that I socketed and they're rewriteable They have to be UV-erased though.
/dev/null, thanks, I'll try stockGSR then I kinda sorta remembered that you used Crome to import the values into the usdmb16base bin so I figured something between Crome and Uberdata 1.63 was interfering whereas it worked fine with 1.2? I dunno. </TD></TR></TABLE>
With all the bugs in crome i was worried from the beginning.
Old Jan 2, 2004 | 06:57 PM
  #495
Civic TSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">I believe the 27xx256 is write once and not rewritable and the 29c256 is an EEPROM which means you can rewrite as many times as you want on the same chip so get this one.</TD></TR></TABLE>
Found the info:
27C256 are re-writable but must be UV erased (This is what I have)
27SF256 are re-writable and can be erased by the programmer for ~1000 times.
29C256 are re-writable and can be erased by the programmer for ~10000 times. You can reprogram this chip without erasing it. (This is what I'm getting).
Old Jan 3, 2004 | 05:14 AM
  #496
XDEep's Avatar
skip the 27Fxxx (flash) and stick with 29Cxxx (eeprom)
Old Jan 3, 2004 | 07:04 AM
  #497
Civic TSI's Avatar
Default Re: (XDEep)
Good news guys, I tried my 2 step rev limiter (not the ftl/fts in Uberdata) and everything seems in order, boosted 3psi, no cell was thrown. Next step will be to switch from my 345cc to my 450cc and than if everything goes well, I'll be buying some 680cc or 720cc.
Bad news: It's ******* icing today
Old Jan 3, 2004 | 07:15 AM
  #498
cinq's Avatar
Found the info:
29C256 are re-writable and can be erased by the programmer for ~10000 times. You can reprogram this chip without erasing it. (This is what I'm getting).</TD></TR></TABLE>
There is a place in Canada that sells them for really cheap. $4.95 each.
Old Jan 3, 2004 | 09:14 AM
  #499
Civic TSI's Avatar
Default Re: (cinq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cinq &raquo;</TD></TR><TR><TD CLASS="quote">There is a place in Canada that sells them for really cheap. $4.95 each. </TD></TR></TABLE>
And where is that place ?
Old Jan 3, 2004 | 09:17 AM
  #500
bigwig's Avatar
POST 500 FOR THIS TOPIC!
