needing some in put going to b redoing my engine
Old May 10, 2007 | 01:50 PM
crxsir23's Avatar
Default needing some in put going to b redoing my engine
im going to be sleeving my block and getting a better turbo soon. my question is should i go 83mm to 84mm bore or stay at 81.5mm. my goal is 600hp to 650hp on my b16 with a gt35 or sc61. i see people with 81mm bore making the some Numbers im wanting and people with 84mm making the same. so looking for some in put on this.
Old May 10, 2007 | 02:15 PM
SD_Lurker's Avatar
HT White Ops
Default Re: needing some in put going to b redoing my engine (crxsir23)
All the bore sizes mentioned above are indeed capable of making the amount of power your shooting for. The bigger bore sizes have some advantages over the smaller bore sizes. An 84mm will build boost faster than the smaller 81-81.5! Also, it will take less amount of boost to reach your desired HP range. I couldn't give you an exact number though. Its really how you wanna build you motor. I will be going with 81.5 for the reason that I should have plenty of rebuilds in case of a mishap where as the 84 your limited to a few more.
Old May 10, 2007 | 02:57 PM
crxsir23's Avatar
Default Re: needing some in put going to b redoing my engine (SD_Lurker)
thanks i was think about probables later on also so i mite go Little smaller at first if i can get the same numbers with just a Little slower spool i forgoer wont be all that much slower
ej1252
Dec 17, 2007 12:20 AM
importsolutions
Jun 25, 2004 06:48 PM
94si94cx
Apr 6, 2004 11:54 PM
2ltrsnailpwr
Jun 23, 2003 02:06 PM
egboost
May 6, 2003 08:57 PM
