Bore to what??
Old Dec 8, 2007 | 09:00 PM
ej1252's Avatar
Default Bore to what??
i just got some sleeves and the bore is 83mm and my question is should i have it bore to 84mm or just leave it 83mm?
IMO, i think i should just leave it 83mm for the next time cause i might need to bore it again in the future, plus im gonna boost the **** out of the motor.
let me know what you think, just wanna see what ideas are out there and what would you do.
its a B16A block and ain't the max bore 85mm before the walls get to thin?
Old Dec 8, 2007 | 09:02 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
get it check and make sure the walls are good.. if so just leave it.. if not then bore... even if you bore it to 84 you still have 84.5 and 85mm if you want to go ahead and do it
Old Dec 8, 2007 | 09:16 PM
TheShodan's Avatar
Moderator
Default Re: (tannerLSt)
The bore is a good idea, but automotively speaking, it doesn't give near the same result with more torque as increase the STROKE of the motor. With a bore only, look to about maybe 20ft/lbs of additional torque, while most I've experienced gained about 60ft/lbs with less bore and more stroke of the engine. Considering that you have a b16, you're pretty used to the "torqueless wonder" anyway. Not trying to burst any bubbles of joy here, just want you to understand and not overestimate your expected result from doing this.
Good luck, I'm quite sure you'll do just fine..
Old Dec 9, 2007 | 10:18 AM
civicb18Tkid's Avatar
if the cylinders are new then i would just have them honed to .050 clearance from the pistons.
Old Dec 9, 2007 | 03:36 PM
TheShodan's Avatar
Moderator
Default Re: (civicb18Tkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb18Tkid &raquo;</TD></TR><TR><TD CLASS="quote">if the cylinders are new then i would just have them honed to .050 clearance from the pistons.</TD></TR></TABLE>
for that HP, that's fine.
Old Dec 9, 2007 | 05:23 PM
.adam.'s Avatar
you mean .0050?
Old Dec 10, 2007 | 08:27 AM
TheShodan's Avatar
Moderator
Default Re: (.adam.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .adam. &raquo;</TD></TR><TR><TD CLASS="quote">you mean .0050?</TD></TR></TABLE>
Yes, but we got his point.
Old Dec 10, 2007 | 10:48 AM
yea.... but zeros dont matter anymore lol
Old Dec 10, 2007 | 11:54 AM
SpoolnG2's Avatar
I'd say leave it at 83mm and just hone it before you put the pistons in to get a nice finish on the walls. I dont think theres a need for any bigger then that, and like you said, that leaves you with plenty of meat on the sleeves and plenty of chances to reuse the block if anything happens.
Old Dec 10, 2007 | 02:39 PM
ej1252's Avatar
Default Re: (SpoolnG2)
ok 83mm it is sounds like a plan. thanks
Old Dec 16, 2007 | 08:00 AM
SteamedRice's Avatar
Default Re: (ej1252)
what company made the sleeves?
Old Dec 17, 2007 | 12:20 AM
ej1252's Avatar
Default Re: (SteamedRice)
SAME ONES AS BELOW,
DARTON MID PRO-KIT
crvtkllr
Nov 29, 2006 05:33 AM
Sportsaddict_21
May 13, 2006 02:25 PM
hondaapi
Dec 7, 2004 02:06 PM
1.8EG-T
May 16, 2002 12:42 AM
