My bore for turbo!!
Old Jun 17, 2003 | 10:07 PM
2ltrsnailpwr's Avatar
Default My bore for turbo!!
Engine is at machine shop being sleeved w/ darton solid decks and bore & honed to 84 mm
Correct me if im wrong--84 mm is far from to big for high boost...
Just trying to clear up rumors or get opinions
Im sayin
Old Jun 17, 2003 | 10:10 PM
TurboDANDEE's Avatar
should be fine.
Old Jun 23, 2003 | 02:06 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: My bore for turbo!! (B18egHatch)
I know RS Machine and GE sleeves as well as Darton are fine up to 86mm maybe beyond for All Motor. 84mm is about the largest I would run on a high boost street car. It isn't necessarily needed. A lot of guys are all about the 82-84mm bore. Yeah it's good for a little quicker spool-up and yeah it will make a few more hp at at certain boost levels vs stock bore, but personally you can make plenty of power on the stock 81mm bore plus you have a lot more room to work with should something go wrong, little safer as well. Just food for thought.
b20vtech
Oct 2, 2007 02:14 PM
crxsir23
May 10, 2007 02:57 PM
ttracing03
Apr 1, 2006 02:43 PM
94si94cx
Apr 6, 2004 11:54 PM
boomslang
Jun 17, 2002 08:10 PM
