need some help understanding this *searched*
i'm about to buy this turbo next week, i'm just having a hard time wondering if this is a good application on an LS, once again my goal hp wise is only 300whp.
175-450+ HP T3/T04E 0.63/0.60 A/R 54 trim
^specs on the turbo, should i go for the .57trim? i tried looking through the LS turbo thread and diden't find anyone else with this spec turbo. any input would be great, it's also a new garette turbo. TIA
Re: (Flexin5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexin5 »</TD></TR><TR><TD CLASS="quote">how will the 54 trim work? </TD></TR></TABLE>
Almost just as well as the 57 trim or 50 trim. Here is a thread for you to read through. It is with respect to the 50 trim vs the 57 trim, the 54 will spool slightly faster than the 57 and a bit slower than the 50 (in theory). If you can get the 54 for a really good price then get it. If not, go with the 57 or 50 depending on you max hp goals for the future. GL.
Re: (KeyserSoze)
The 50 trim would suit a 300hp goal slightly better than the 54 trim. I would personally go with a 50 trim .48, you would be nearly maxing it out but the spool time will be insane and amazing on the street.
Before i blew a piston ring i was running a 57trim .63 on a stock gsr aiming for 300 HP, I was thinking of swapping to a 50 trim .48, but now I will be pushing the 57trim (max 450hp).
98-DC4
03-10-2008 05:37 PM
