Need little help on oil feed line.
Ok so friend told my oil feed line go where my oilpressure sensor is is that right? if so is there any way i can get fitting so i would have my oil pressure sensor still plug in?
Re: Need little help on oil feed line.
If you wanna tap of the oil pressure line, get a kit from www.stealthmodeperformance.com. They have a fitting that allows you to keep the sensor.
If you want, you could always use an oil sandwich adapter and source oil from there.
huepowered
05-19-2006 05:50 PM
CivicNewbie
01-24-2002 07:01 PM
