need help with oil return
Old Jan 8, 2003 | 09:20 AM
thejdmkid's Avatar
Default need help with oil return
I know that I need a flange for the oil return & oil feed lines. I looked on cheapturbo.com) either i'm blind or just can't find it. its for a t3t4oe your help is welcome. thanks
Old Jan 8, 2003 | 09:28 AM
KC GSR's Avatar
Default Re: need help with oil return (thejdmkid)
Garrett Oil Drain Flange with 5/8" hose barb fitting
http://www.roadraceengineering.com/f...andgaskets.htm
Towards the bottom of the page
Old Jan 8, 2003 | 09:43 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: need help with oil return (KC GSR)
http://store.yahoo.com/cheapturbo/t3bilaloilre.html
mos's Avatar
mos
I have that. It's got a 1/2 NPT thread in the aluminum, and they give you a 1/2" NPT to 5/8" barbed brass fitting along with it.
Edit: Don't forget, might as well buy a gasket while you're ordering.
[Modified by mos, 10:45 AM 1/8/2003]
Old Jan 9, 2003 | 06:04 PM
thejdmkid's Avatar
Default Re: need help with oil return (mos)
what about to the turbo from the block. i'm using the greddy adapter palte from the oil filter to feed oil to the turbo. i have the earls fitting and ss line. is there a flange I need to plug the feed line into the turbo itself. once again thanks
Old Jan 9, 2003 | 06:46 PM
johnisenglish's Avatar
https://honda-tech.com/zerothread?id=232145 - covers all of this
I got my oil feed lines and fittings from http://www.secureperformanceorder.co...6&CategoryID=3
and my return from SouthFloridaPerformance
EGtoua
May 20, 2011 08:53 AM
ShawnR
May 11, 2007 01:07 AM
Ad4mGSR
Jun 4, 2004 12:32 AM
420aNT
Feb 8, 2003 12:22 AM
