Bullseye S362 oil feed and return fitting help
okay i have a bullseye s362 turbo and i tried looking for feed and return oil fittings for it but cant find any. it seems like it needs a adapter plate then the fitting. if you can help me out it would be great! thanks!
Re: Bullseye S362 oil feed and return fitting help
We have fitting kits for them. If the turbo doesn't have a threaded inlet then you need an oil inlet flange.
PM me with your setup and I'll get you squared away.
b18cya
02-19-2003 10:50 PM
