Why dont my check valve setup work?
Old Aug 11, 2002 | 02:17 PM
Integra_Boi's Avatar
New User
Default Why dont my check valve setup work?
i'm running 3 check valves from the throttle and i used T's to do them... i'm just wondering why other people are using them and arn't throwing any cel's off.. or are they?.. i can get away with first and second gear.. but third gear will definetly throw my CEL On...
Old Aug 11, 2002 | 05:12 PM
filetofit
Guest
Posts: n/a
Default Re: Why dont my check valve setup work? (Integra_Boi)
Yeah, I had the same problem. keep adding check valves 'til it goes away. Three is a good start but I needed more. The problem is those @!#$%&* check valves don't flow enough to relieve the pressure. Or buy an electronic MAP limiter from me for $20. Or buy a missing link, even those poop out I hear at about 12 psi (not sure on that number).
Old Aug 11, 2002 | 05:18 PM
filetofit
Guest
Posts: n/a
Oh yeah I forgot to add, you can try small diameter vacuum tubing from the manifold to the check valve tee and large diameter tubing from the tee to the MAP sensor and from the tee to the check valves. You could also try partially restricting the vaccum line from the manifold to the tee with a paper clip or tie wrap or something, and punching a small hole with a hot pin in the line from your tee to the MAP sensor. Good luck.
Old Aug 11, 2002 | 05:27 PM
New User
Default Re: Why dont my check valve setup work? (filetofit)
that paper clip thing sounds good for now.. well i already got a missing link coming in now.. thanks
Old Aug 11, 2002 | 05:39 PM
rjardy's Avatar
are you guys sure that they (checkvalves) are in the right way?
Rob
Old Aug 11, 2002 | 07:03 PM
New User
Default Re: Why dont my check valve setup work? (rjardy)
yup! i blew on it myself hahahah
turbohybridhatch
Mar 17, 2005 07:05 PM
W.Zero
May 1, 2003 01:33 PM
filetofit
Jun 4, 2002 02:56 PM
integraracer94
Jun 2, 2002 06:34 PM
turbotec
Feb 26, 2002 03:34 PM
