My first FI setup, all help is beneficial
Setup
b16 stock
turbonetics t3/t4 turbo
drag manifold
tial wastegate
hks bov
rc 750s
3 bar map
My plugs are black smells like fuel from exhaust, only running 40lbs of fuel pressure, and no boost is showing if i rev my motor but my BOV is blowing off?? stumped, this i my first FI setup alwasy been all motor, so all help is beneficial.
b16 stock
drag manifold
tial wastegate
hks bov
rc 750s
3 bar map
Re: My first FI setup, all help is beneficial (Rukusmasta2)
It's kind of hard to get any boost to build when you got no load on the motor. Take it to a tuner. What EMS?
you should tune it asap. If the car is just running on a base map then it's probably running really rich / "safe" .. thus making the plugs smell like gas. as for the bov.. my last setup would "blow off" or make noise without boost just revving the engine.. i think its just due to the changes in vac.
Base map is not correct for your setup.I don't care if your running 8 or 80 psi.Have it tuned or learn to tune it your self, those are the two options.
Re: My first FI setup, all help is beneficial (NJIN BUILDR)
1) Get the car tuned. The gas you smell is likely your car running VERY rich. A tune will take care of that.
2) Your bov is not actually blowing off.....it just creeps open and closed right? Mine does the exact same thing when I rev it with no load on the engine (50mm tial). You're not gonna build boost with no load on the engine unless your utilizing a two step or the like. If you really don't like the bov cycling like that then get a slightly stiffer spring for it.......GL
