turbo lude, acting really sluggish??????????
i have a turbo prelude, and for some reason it has no ***** whatsoever, it was boosting fine all day long, i got in it after dinner, it boosted good, after a stop light it barely boosts, no boost leak checked all the ic piping,changed my plugs, dont know what it could possibly be, please help!!!!!!!!!!!
Re: turbo lude, acting really sluggish?????????? (blackssvtex)
I think everyone here will need more information on your setup to be able what is really going on, so list your setup and what motor its on.
Also what are you running for fuel??
Adi
Adi
are you running check valves or the missing link map sensor? If you are running check valves, they most likely took a **** on you and you will need to replace them. Also just out of curiosity, what motor do you have and are you throwing any codes?
Re: turbo lude, acting really sluggish?????????? (MiraiZ)
it is a drag 3 kit with a tial wastegate, greddy bov and fmu, walboro fuel pump, it does not boost at all, it seems like its working against itself, i have no freaking idea but its really pissing me off , there is no boost leaks, its not the air either, revving in neutral air gets blown off from the bov but not what it should be, i dont know!!!!!!
my car would boost like crazy for about 5 or 6 runs, then feel sluggish... i found it was heat soak... everything was hotter than hell so i'd spray the i/c down with some icee cold water and then she'd boost again
maybe that's not your problem but a possible easy fix.
Re: turbo lude, acting really sluggish?????????? (The Maryland Truth)
it is an h22 and it is not heat soak, now it is way worse it wont go past 5 grand in 2nd gear , i have new plugs in it, ahhhhhhhhh, it like the freaking turbo is spooling in the oppisite direction!! lol i cant figure it out, can an fmu go bad, or get clogged or something?
sounds like you've got too mcuh fuel in there... my car would do that a lot and i was running below a 10:1 (the wideband would go only to 10:1... then it would shut off, so wahtever i was at was less than 10:1)
-ryan
-ryan
Re: turbo lude, acting really sluggish?????????? (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">are you running check valves or the missing link map sensor? If you are running check valves, they most likely took a **** on you and you will need to replace them. </TD></TR></TABLE>
for the second time, answer this.
Re: turbo lude, acting really sluggish?????????? (psileepR)
i had the factory ngkr's in there when i was running perfect, i put autolite platinums in , they are the same gap, .44 i think , and the same heat range, shouldnt be that , it was running great with the fatory plugs in it
u need to lessen the gap. maybe like a 28-32 somewhere in that range.
also a colder plug
bcpr7es
did u burn up a plug?
also a colder plug
bcpr7es
Fired Honda
06-30-2003 08:27 PM
