mitsubishi/ greddy turbo's - how to run lower boost on the internal wastegate?
Can they be modified to run lower boost?
I'd like to run 5psi off the internal gate and use a boost controller to run higher boost for 3/4/5 gears.....
Has anyone modified theirs?
My greddy 18g internal gated holds 9psi just fine. Nice and stable without any creeping or spiking. But I'd like to be able to run lower boost in 1st and 2nd gear.....
Thoughts?
Thoughts?
Re: mitsubishi/ greddy turbo's - how to run lower boost on the internal wastegate? (Black R)
Port the WG hole if you want to run lower boost, else it will creep, it is good to port that hole anyways. There is a ton of material you can remove and keep the stock sized flapper.
You can loosen that threaded rod so it will make like 5 PSI off the WG then set the boost controller to whatever you like. FWIW, why do you want just 5 PSI in 1st gear? I run 1 bar on the same turbo and it wont make full boost in 1st anyways, maybe .6 bar. Also you can pick up a Forge Motorsports actuator, they have replaceable springs in them so you could set a lower base boost with a lighter spring then use the boost controller to raise it from there.
Re: mitsubishi/ greddy turbo's - how to run lower boost on the internal wastegate? (nfn15037)
Thank you very much.
Forge motorsports? I guess I'll google them.....
Ya they are a UK based company, I ended up eating the few bucks and calling them, it is the only way to get ahold of them. You would think that a company would want you to spend your money with them, but not these guys lol. I do still highly recommend porting the WG hole, it made such a huge difference on my Greddy setup along with a 2.5 inch downpipe.
I took a 16G, took the flapper and arm off, took the arm off the flapper, ground it down a tad, and welded the flapper over the whole and ran a tial....perfect .3 bar everytime, then a manual boost controller to increase it.
Re: (quik sol)
Would there be any downside to useing two wastegates so long as they are both at the same spring? or even if the internal is set to a higher spring it should still work fine/better?
Re: mitsubishi/ greddy turbo's - how to run lower boost on the internal wastegate? (Blue00vtecsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue00vtecsi »</TD></TR><TR><TD CLASS="quote">Man dont be afraid of it boost it </TD></TR></TABLE>
haha, not afraid of it - just no traction in 1st and 2nd gear.....!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 »</TD></TR><TR><TD CLASS="quote">Ya they are a UK based company, I ended up eating the few bucks and calling them, it is the only way to get ahold of them. You would think that a company would want you to spend your money with them, but not these guys lol. I do still highly recommend porting the WG hole, it made such a huge difference on my Greddy setup along with a 2.5 inch downpipe.</TD></TR></TABLE>
Is this them?
http://www.forgemotorsport.co.uk/
I can't figure out wtf to order from their website.....
Is this them?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Good info.
*TOTAL THREADJACK BUT IT SHOULD HELP US ALL*
I may rebuild my turbo in the near future. I was considering replacing the compressor wheel with a 16G compressor wheel, in order to hit 300whp. I have heard that turbochargers.com can do it, have you heard of people modding actual turbos with different compressor wheels to gain more WHP?
Good info.
Re: mitsubishi/ greddy turbo's - how to run lower boost on the internal wastegate? (boostincoupe)
I Found the car had a much nicer powerband on low boost with boost creep.
If 10 pounds wasn't so much faster than the wastegate setting, i'd not use the boost controller and enjoy a better linear pull.
