Internal Wastegate Boost Controller
Old Dec 14, 2003 | 04:29 PM
jovial111's Avatar
Default Internal Wastegate Boost Controller
I have a T3 turbo with an internal wastegate. I want to hook a manual boost controller up to it but I'm not exactly sure how. There are two threaded holes on the wastegate. one is labled "boost" and has a hose going towards the compressor nipple. The other is left open but has a pinhole at the bottom of the hole.
1: If the wastegate is internally set for 15psi, can I set it to run lower by running an boost controller?
2: If so, where do I mount the boost controller?
Old Dec 14, 2003 | 04:37 PM
DA-MAX's Avatar
you can't run boost any lower than what the WG is set for...if you wanna run lower than 15, you'll need a new WG altogether
Old Dec 14, 2003 | 07:26 PM
boostn420's Avatar
Default Re: (DA-MAX)
you can try pluging the oriffice, it a bleed there to increase boost, so plugging it might lower it. Otherwise its ginna have to be changed.
Old Dec 14, 2003 | 07:29 PM
jovial111's Avatar
Default Re: (boostn420)
On a related note, what boost are turbos off of turbo diesels set to run?
Old Dec 15, 2003 | 04:39 PM
aut0kill3r's Avatar
Default Re: (jovial111)
y0, why cant you just hook up some nos to the wastegate for a instant hp gain during the powerband but you have to be careful about that because youll blow up your engine or throw a rod if you boost too much. can i boost a 100shot on my car?
b20vtech
Jan 24, 2008 05:55 PM
superhatchbackbros
Jun 30, 2007 09:17 AM
hold your breath
Mar 6, 2007 07:47 PM
stockgreencivic
Apr 10, 2003 07:32 PM
