Max power on t04e B16
Hi!
How much power is possible to get from a T04E Turbo on a b16 engine, and at how much boost? Together with 9,1 CR ?
Modified by YASH at 10:02 PM 10/21/2004
More details. Is it a TO4E 50 trim, is it a TO4E 57 trim, is it a TO4E 60 trim, is a 60-1 wheel in a TO4E housing, is it an SC61, is it a GT35E, **** it could even be a T67 wheel in a TO4E housing. What exhaust wheel, what exhaust housing are you running? Too many variables to give you ANY kind of an answer on a vague question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe »</TD></TR><TR><TD CLASS="quote">More details. Is it a TO4E 50 trim, is it a TO4E 57 trim, is it a TO4E 60 trim, is a 60-1 wheel in a TO4E housing, is it an SC61, is it a GT35E, **** it could even be a T67 wheel in a TO4E housing. What exhaust wheel, what exhaust housing are you running? Too many variables to give you ANY kind of an answer on a vague question.</TD></TR></TABLE>
I think it's a 50 trim, the others i donno for sure
it has 360" bearing and stage 5 axle, on a Ford Escorth Cossworth they can produce over 400hp easily, they recomended max 2 Bar ~ 28 PSi.
Modified by YASH at 10:19 PM 10/21/2004
it has 360" bearing and stage 5 axle, on a Ford Escorth Cossworth they can produce over 400hp easily, they recomended max 2 Bar ~ 28 PSi. Modified by YASH at 10:19 PM 10/21/2004
94integragsr
Jul 19, 2005 02:31 PM
dustineck
Nov 17, 2003 04:10 PM
