Got my Turbo on! Vafc Hack question
Old Feb 24, 2003 | 12:35 PM
b18cya's Avatar
Default Got my Turbo on! Vafc Hack question
ok, got the turbo on, running 5 psi non-intercooled (will be running 7 psi with a boost controller) & 310cc injectors
i ran -25 across the board, how much more do you think i can cut it
310cc injectors
7 lbs of boost
5280' elevation
Old Feb 24, 2003 | 12:59 PM
r4adkshn1's Avatar
Default Re: Got my Turbo on! Vafc Hack question (b18cya)
every car's different. i would leave it there until u get some way to monitor ur A/F ratio. even tappin your stock o2 w/ a multimeter will warn of lean conditions.
Old Feb 24, 2003 | 07:43 PM
ModlesSI's Avatar
New User
Default Re: Got my Turbo on! Vafc Hack question (r4adkshn1)
Hrm, i also plan to try the VAFC hack w/ the 310's.... let me know how things work out
Old Feb 24, 2003 | 07:55 PM
turbosol's Avatar
Default Re: Got my Turbo on! Vafc Hack question (ModlesSI)
You are pushing you luck trying to run the afc hack with 310s, even with low boost. Good luck.
Spend $50 and get some DSMs http://www.dsmtrader.com
zojirushi's Avatar
theres no way your gonna be able to run the hack with 310's with stock fuel pressures..... get bigger injectors
brandond
May 2, 2004 09:43 AM
1.8T_EG
Dec 9, 2003 09:11 PM
b18cya
Dec 20, 2002 05:48 PM
1.8T_EG
Sep 16, 2002 12:22 PM
ZCPOWER
Aug 1, 2002 01:44 PM
