turning up the boost?
Old Apr 16, 2013 | 08:27 PM
Hiboost 2.0's Avatar
Icon2 turning up the boost?
ok i have a bone stock b18b1 it was tuned on 8psi. So i ordered a manual boost controller an i got thinkin to my self my tuner tuned my car with that map unplugged so what can i turn it up to 11psi?
Old Apr 16, 2013 | 08:53 PM
Muckman's Avatar
Moderator in Chief
Default Re: turning up the boost?
What map unplugged?
No you cannot increase boost beyond the point it was tuned to unless you like rebuilding engines.
Old Apr 16, 2013 | 08:58 PM
Originally Posted by Muckman
What map unplugged?
well i did call him to ask if it was safe he told me anything after 12 id need a retune an map sensor
Old Apr 16, 2013 | 09:02 PM
Muckman's Avatar
Moderator in Chief
Did he say it was safe to increase boost beyond 8psi?
Old Apr 16, 2013 | 10:34 PM
yungkhmer's Avatar
from my understanding, you can only decrease psi from what you were tuned at and itll be fine. you just cant UP the boost. Gotta get a retune for higher psi.
Old Apr 17, 2013 | 03:01 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
If the car was tuned for 8psi what makes you think it can do 11-12psi?
Old Apr 17, 2013 | 08:30 AM
boosted_D's Avatar
you are referencing the fact that the stock map sensor can only read up to 11 psi, which is true. But if you were only tuned to 8 psi, when you turn it up to 11 psi, the map is going to use the same values from 8 to 11 psi, therefor you will be un-tuned beyond 8 psi risking damage, you need more fuel and less timing from 8 to 11 psi, your ecu wont know this because it hasn't been tuned for more than 8 psi... will it run, yes, will it blow up if you dont re tune it, probably....
Old Apr 17, 2013 | 08:46 AM
slowman's Avatar
I took way too long
Wouldn't recommend that.
Old Apr 17, 2013 | 09:53 AM
shawty22's Avatar
Sounds like a good idea. In for the results.
Old Apr 17, 2013 | 01:42 PM
92cxturbo's Avatar
Not saying a retune for more boost isn't nessacary, but this is false. Just because the car was tuned to 8 psi doesn't mean the fuel/timing values at 10psi are set the same as 8 psi that would be not very smart on the tuners part.
Old Apr 17, 2013 | 06:04 PM
my mistake "REASON FOR NO MAP BEING PLUGGED IN" car has a 3bar i spoke to the tuner he said 10-12psi just watch the A/F they need to be low12 high 11's
Old Apr 17, 2013 | 06:21 PM
Muckman's Avatar
Moderator in Chief
Alright good luck. Let us know how it goes!
Old Apr 17, 2013 | 07:16 PM
SiRCiviC94's Avatar
some tuners will have the timing values relate to boost pressure...fuel too possbily. I ran about 10-11psi when i had to get it done lol it held up ok
Old Apr 17, 2013 | 08:07 PM
How much psi was the car tuned on until you bumped it up an what program did you use I was using the Crome pro I just hope things don't go downhill from turning this up lol
Old Apr 17, 2013 | 08:14 PM
MR.johnson's Avatar
1badteg
Jun 24, 2009 02:00 PM
97grnrs
Jan 9, 2008 09:57 AM
the.hamburglar
Aug 2, 2007 02:44 PM
f1 vtec
Nov 1, 2004 09:38 PM
Crazy Cooter
Nov 4, 2003 05:02 PM
