3 Bar Map Sensor help
Old Jul 9, 2008 | 02:26 PM
LSej1's Avatar
Default 3 Bar Map Sensor help
I've been reading around about the 3 bar map sensors. I know they are required to be used if you are running 12+PSI of boost. Can they be used with lower boost as well? I will be running 9psi daily... If you have any ideas on good deals and info on these can you please let me know
Old Jul 9, 2008 | 02:33 PM
1fastlude1's Avatar
Default Re: 3 Bar Map Sensor help (LSej1)
ya you can run 9 psi but if your not going to boost above that theres no need but if you have further plans with it i would go ahead and run it
Old Jul 11, 2008 | 03:21 AM
LSej1's Avatar
Default Re: 3 Bar Map Sensor help (1fastlude1)
Well i havent decided if i am going to go with boost by gear/RPM or get a boost controller. Either way i think ill be running 9psi and 11 or 12 at the track.
Old Jul 11, 2008 | 04:08 AM
Schister66's Avatar
Man U FTW
With the GM 3bar, you can run anything up to 29psi. If you think you might go over 11psi in the near future, there's no reason not to get one.
Old Jul 11, 2008 | 05:31 AM
totsie7944's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">With the GM 3bar, you can run anything up to 29psi. If you think you might go over 11psi in the near future, there's no reason not to get one. </TD></TR></TABLE>
I'd get the omnipower 4 bar...mine works great and is plug n play....Sooo much easier to install not having to wire anything
Old Jul 11, 2008 | 08:06 AM
DaveF's Avatar
you can run past that number as well. its just that the fuel will only follow that last column on the table.
Old Jul 11, 2008 | 07:12 PM
mtber's Avatar
Default Re: (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">
I'd get the omnipower 4 bar...mine works great and is plug n play....Sooo much easier to install not having to wire anything</TD></TR></TABLE>
+2 I love them 2 bolts & your done.
Old Jul 19, 2008 | 03:51 AM
90crxdriver's Avatar
Default Re: (mtber)
sorry to thread jack...
I'm running 7 psi with no plans to go higher. Can a tuner make the stock map sensor work (I do have a missing link installed just to keep the CEL off while I test.) Or should I get the gm 3 bar map senor?
thnaks
92redhatch
Aug 11, 2012 12:55 PM
ashb82
Engine Management and Tuning
Sep 3, 2009 03:29 AM
the.hamburglar
Aug 2, 2007 02:44 PM
vu337
Oct 24, 2005 04:50 PM
paulzy
Dec 5, 2001 10:04 AM
