ls/vtec
Old Nov 12, 2002 | 03:19 PM
TheHater
Guest
Posts: n/a
Default ls/vtec
If I have a greddy tc on a b16a2 and I want to convert by b16 block to a ls vtec will everything still fit correctly.
Old Nov 12, 2002 | 04:12 PM
TheHater
Guest
Posts: n/a
Default Re: ls/vtec (BOOSTINSI)
upupup
Old Nov 12, 2002 | 04:41 PM
Boost2NA's Avatar
Im kinda confused here. If you are going Ls-Vtec you dont even use the b16 block. I think what u are asking is if you are running the LS block will your turbo kit still work on the new block. The answer to that is yes only that thing I recommend doing is dont tap your oil sending unit twice. On my set up we used the oil sending unit for the turbo and we tapped the one of the oil passage ways on the back of the block for the head. You will love the LS-VTEC turbo.
Old Nov 13, 2002 | 08:10 AM
TheHater
Guest
Posts: n/a
Default Re: ls/vtec (Boosted99Si)
NONONO... I have a b16 engine and in the future if id like to change the bottom end to a ls/vtec will my greddy kit still fit?
Old Nov 13, 2002 | 08:11 AM
TheHater
Guest
Posts: n/a
Oh I read your post again. OOpps you answered my question. Sorry
Old Nov 13, 2002 | 04:40 PM
Doogie Howser's Avatar
how bout a ls crank?
Old Nov 13, 2002 | 05:32 PM
Boost2NA's Avatar
Default Re: ls/vtec (mlambrecht)
LS crank is good. Just make sure you get it balanced. The LS cranks can be off quite a bit.
Old Nov 13, 2002 | 06:20 PM
correct me if im wrong but an ls crank would bump it to 1.8 right, isnt the b16 bore 81.5, it just has a shorter stroke..?
Old Nov 13, 2002 | 06:24 PM
Boost2NA's Avatar
Nope. B16 bore is the same . They are both 81mm. The stroke on the LS crank is longer, therefore it wont work in your B16 block. The B18 blocks are actually a little taller the the B16 blocks. Hope this helps
Old Nov 13, 2002 | 06:36 PM
what about a b17a crank, are the b16 and b17 blocks the same height?
igotthaspirit
Nov 9, 2006 07:29 AM
Deano_D aka "Brick Top"
Sep 30, 2006 12:07 AM
whiteknightef
Mar 30, 2004 10:00 AM
dc2_and_ef
Jan 3, 2004 05:58 AM
b18b-HB
Oct 25, 2002 09:04 AM
