ls/vtec ????
Old Oct 24, 2002 | 11:48 PM
b18b-HB's Avatar
Default ls/vtec ????
I am looking at building a ls/vtec turbo first off how hard is this to do?
Also what will happen if I put the b16 crank into the ls block (is that just flat out stupid) will it work for low com....
thanx
Old Oct 25, 2002 | 09:04 AM
Vu's Avatar
Vu
Default Re: ls/vtec ???? (b16civict)
http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
Putting the B16 crank in the LS block will give you a shorter stroke, reduce your displacement to 1.6L, and give you a better rod ratio so you can rev higher, safer. But why not just get a B16 motor than?
Deano_D aka "Brick Top"
Sep 30, 2006 12:07 AM
Sick'Lude
Oct 13, 2005 06:45 PM
whiteknightef
Mar 30, 2004 10:00 AM
eg360B
Mar 1, 2004 11:44 PM
dc2_and_ef
Jan 3, 2004 05:58 AM
