Ls turbo setups
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artist7 »</TD></TR><TR><TD CLASS="quote">also i am most likely going to upgrade my radiator before i even go get the compression test.. from eper. does anybody know which brands i should take a look into ? </TD></TR></TABLE>
It doesn't matter..I got one for $25 at autozone and I checked my compression then returned it within the hour saying that I had a diesel and this thing didn't work for it....like I was the dumbass
edit: If your numbers are low it just means that you have excessive (sp?) blow-by. Its more important to have a strong engine that doesn't leak or have many problems as these problems will be multiplied by the turbo. If they are low and you don't feel like getting your engine rebuilt then make sure everything else is in tip top shape. Anyone else agree with this? I'm saying this so people don't think that if they have good compression that it's OK to turbo and vise versa
thanx for the info but i dont think i worded my post correctly.. i mean t to say just about the first thing i will do is change my radiator cause i dont think the one the ls i am looking at is any good.... i was just wondering which brands are top notch since i want to make sure to get thisout of the way before i start my Ls transformation.. but still thanx for that needed information before
ok i was kinda wondering this, and i think this is the thread to ask it in....would running a t3/t4 50 or 54 trim with a .48 turbine a/r be too small for a b18b up around 12-15psi max? this thread opened my eyes to an ls turbo to follow up my stolen d16turbo, and i would be looking to run a t3/t4 with a .48 turbine for quicker spool
I run a T3/T04E on my LS. It's .60 A/R compressor and .48 A/R turbine, 60 trim, stage 3 wheel. I am currently only running 8psi, but I think it's capable of a ton more. I love the quick spool and power of this turbo.
can one of u guys help me out?
https://honda-tech.com/zerothread?id=935006
I need a close up picture of ure engines
Im running the stock LS tranny (not sure about tranny code) but either way im nto boosted yet.
Im contemplating which turbo to get. Garret T3T4 60 trim .60 a/r compressor/.63 a/r turbine, Or should I go with a .48 turbine?
I want a goal of lower 300hp levels. Im sure the .48 can get me there. But if i ever wanted to go higher the .63 could always go higher.
Also i saw someone before said there where going to install crower 403T Camshafts I was looking around and i could only find 402t's, can somebody gimme a linkto a site that has them
Modified by artist7 at 7:04 PM 7/22/2004</TD></TR></TABLE>
I am running the crower LS 404s their not that bad like people have said!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED »</TD></TR><TR><TD CLASS="quote">i have a b18b1 ls motor in my EK with tdo5h turbo. its the same size as t25 but more efficient. spools FAST unlike t3's and t4's and way better for the streets. with t3's and t4's by the time u spool up ur competition is 5 cars away...lol
tdo5h was slow at upper rpm but unless u get like a tiny *** 14b or something turbos keep making HP anywhere in the rpm range, just how efficient...depends on the trims</TD></TR></TABLE>
Umm, the tdo5H is a 14b and it's bigger than a T-25.
as for turbo: t3/to4e .63 turbine, .60 compressor .57 trim.
top end power takes my breath away
as for tranny choice: GSR tranny w/Kazz 1.5way LSD
watch out for my 3rd gear pull!! oh yeah, corners are cake walk as well
here is my LS-T
97 b18b stock with arp head studs
ls tranny
lovefab sst
(dragIII turbo)t3/t04E .63a/r turbine 54 trim stage 3 wheel .50a/r compressor
3in. downpipe
spearco IC
2.25" piping
walbro 255
750cc injectors
hondata s200b
tial wg/bov
3bar map
tuned to 6.5 psi 213whp/190 tq ran 12.73 @103 mph(with ssautochrome manifold)
recently tuned to 11 psi 267 whp/ 240 tq with air temp at 106
waiting to see what it will run.
ls tranny
lovefab sst
3in. downpipe
spearco IC
2.25" piping
walbro 255
750cc injectors
hondata s200b
tial wg/bov
3bar map
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2speedha »</TD></TR><TR><TD CLASS="quote">here is my LS-T
ls tranny
lovefab sst
3in. downpipe
spearco IC
2.25" piping
walbro 255
750cc injectors
hondata s200b
tial wg/bov
3bar map
You were definately running some slicks on that run if you made a 12.7 pass with those numbers.
Thats just to answer the question right below this statement. Im sure his 60ft time was somewhere below 2.0....
ls tranny
lovefab sst
3in. downpipe
spearco IC
2.25" piping
walbro 255
750cc injectors
hondata s200b
tial wg/bov
3bar map
this is a great thread ls turbos i luv to see some non vtec setups i dont have a ls turbo setup
i got the bigger brother version b20z turbo :-D
and with what people say that the bigger turboes wont spool. isnt troo i am running a precision sc61 turbo on a stock b20z block with ls tranny :-$ imma waiting to see what she will do on the track havent had time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels »</TD></TR><TR><TD CLASS="quote">Keep in mind that you have .2-.4 liters more displacement then most of the people here (aside from all those damn prelude and rsx guys with their so called ''torque'')</TD></TR></TABLE>
well i dynoed wit my old ls and with my b20z and the dif in torque was alot
112@wtorque i nmy ls to my 130@w torque in my b20z thats a big difference :-D. a ls can still spool it wit the same amount of time i can IMo
