How do I run a Water cooled turbo on a B18C1 Block?
Old 01-28-2019, 08:04 AM
Excusetobooost's Avatar
Default How do I run a Water cooled turbo on a B18C1 Block?
Hey guys I've been searching and searching and have seen alot of different opinions. I will be running a water cooled turbo on my gsr and it's my first time, i always used only oil. My question is if I can feed from the water pipe and the other to the plug in front the block. The plug under the exhaust manifold. Or also my engine has the iacv eliminated, could I use both those lines ?
Old 01-28-2019, 10:39 AM
Autoworks's Avatar
Default re: How do I run a Water cooled turbo on a B18C1 Block?
Yes you can
Old 01-28-2019, 10:55 AM
Originally Posted by Autoworks
Yes you can
Thank you.
Old 01-28-2019, 01:55 PM
Moderator
TheShodan's Avatar
Default Re: How do I run a Water cooled turbo on a B18C1 Block?
That's one way of doing it, yes. But there are other alternatives for kits already being made for water-cooled turbos for Honda B-series VTEC.
B&R Fittings Water Cooling Kit
GT500FTW
05-06-2013 01:48 PM
hmt_eg
02-24-2010 01:29 AM
IntegraGSR-Turbo
05-06-2007 01:52 AM
the.hamburglar
05-01-2004 07:13 PM
specktur
03-04-2004 02:54 PM
Quick Reply: How do I run a Water cooled turbo on a B18C1 Block?
