Lost BOOST
Old Apr 29, 2004 | 09:22 PM
GSRACCORD's Avatar
Default Lost BOOST
I have a greddy turbo kit on my 2000 gsr. At first I was running no intercooler. It was at 8 psi. Today I put the intercooler on and no I am struggling to reach 5 psi. I tried adjusting the lever on the wastegate and it still doesn't work. I also pulled the hose off the wastegate and it still does the same thing. If someone could help me it would be greatly appreciated.
Old Apr 29, 2004 | 09:32 PM
Charles B.'s Avatar
Default Re: Lost BOOST (GSRACCORD)
there is a pressure drop with the i/c but i don't think it should be as much as 3 psi. as far as the actuator i don't think it is adjustable and pulling the vacuum line on it would keep the flapper closed. the first thing i would do is check for any leaks in your piping.
Old Apr 29, 2004 | 09:41 PM
SeanEF's Avatar
Default Re: Lost BOOST (CharlesInTurbocharge)
did you check all your piping to make sure there is no leak??
Old Apr 30, 2004 | 10:17 AM
GSRACCORD's Avatar
Could the actuator be broken or something? I'm going to double check the piping again right now.
Old May 1, 2004 | 09:34 AM
GSRACCORD's Avatar
Anyone?
Old May 1, 2004 | 10:20 AM
lgcubana's Avatar
Default Re: (GSRACCORD)
For diagnostics, remove what was added 1st. Then see if it works.
Specifically to test for leaks, use soapy water around all of your piping seals.
Also did U test your intercooler for leaks ? Plug both end pipes & submerge into water.
ej8_fredi
Sep 12, 2008 11:12 AM
Moto_340
Aug 9, 2007 07:20 AM
99ekb18b
Oct 10, 2006 06:44 PM
misskris220
Jul 7, 2005 04:54 PM
b00stedbyFastrax
May 9, 2004 07:13 AM
