looking for a shelf kit for a b18c1 setup
Old Feb 3, 2013 | 07:10 AM
  #51
TheShodan's Avatar
Moderator
Default Re: looking for a shelf kit for a b18c1 setup
Originally Posted by DAprojectTuRtle
i wont be doing too many full or even 3/4 throttle passes on the street. trying to preserve my clean driving record. But anyways what intake manifold do you guys suggest for the c1 head? Since p72 choices are limited and bbk doesnt seem to be offering one on their site right now.. Oem or maybe skunk2
For most of the intercooler kits come with I/C piping that is made for a B16/Type R or LS style intake manifold which sets the throttle body higher than with the GS-R intake manifold. So most do switch to the Skunk2 because it fits the GS-R cylinderhead bolt pattern, yet at the same time sets the throttle body in the position that most I/C kits (including the go-autoworks kits). This is the only reason why one would normally change the intake for sub-500whp setups. Otherwise, it is not necessary.
Old Feb 3, 2013 | 07:16 AM
  #52
DAprojectTuRtle's Avatar
word. yeah i agree if i was staying all motor my stock intake manifold is quite good. Thanks fellas this has been quite informative for what im trying to do.
Old Feb 3, 2013 | 08:21 AM
  #53
Originally Posted by wantboost
Not true at all, with a proper wheel and housing combination you can have both.
Lightningteg made 300/300 on a stock ls with a gt280 and carried the torque flat all the way to redline.
I can make 400 with a gt2871 and have the top end of a bigger turbo (example a 50 trim) but have the down low torque production that peaks and carries where a larger turbo would just start spooling.
Smaller turbo does not equal little power....people needs to get over this idea that they need huge turbos for a tiny power goal and complain because its too laggy and sucks to drive on the street. You wouldn't dd a gt42r on a b16 now would you?
Comparing a 50 trim t04e to a gt2871 is the same comparison. Why have tons of lag and have a shitty power band as well as a narrow rpm range to use.. especially when you could size a turbo properly for your power goal and purpose of vehicle and have a retardedly huge, fat, torque loving power band - see it all the time at our shop and on various forums.
Please correct me if im wrong, but what i got from this post is that the gt2871 is better than the t3/t4 50 trim turbo i proposed..
Old Feb 3, 2013 | 08:25 AM
  #54
this turbo??
http://www.go-autoworks-store.com/jobegagtt35b.html
or this one
http://www.go-autoworks-store.com/gagtg.html
Old Feb 3, 2013 | 11:59 AM
  #55
TheShodan's Avatar
Moderator
Got a LOT more choices than that.. I'm always a fan of the GT-R series, but you've got TONS to look at.
Old Feb 3, 2013 | 04:04 PM
  #56
ok thanks
Old Feb 6, 2013 | 04:33 PM
  #57
ok well talked to greg at go auto he recommended garrett t3t4 50 trim. 63 ar. I didnt even say thats the turbo i was looking at. I also found this water meth kit im looking at to help with knocking..
http://www.alcohol-injection.com/en/111-integra
Old Feb 6, 2013 | 04:51 PM
  #58
wantboost's Avatar
Who is Mr Robot?
The 2871r will have better transient response (between shifts, etc) as well as a slightly better boost curves... earlier response means a more broad power band vs the 50 trim
However it does cost more.
I'm always a big believer in finding the most responsive turbo for a given power goal... no point in having a 400hp car that has a 2000-3000 rpm power band
Old Feb 6, 2013 | 05:53 PM
  #59
i dont see that turbo on their site.. im trying to buy the whole kit at first from one company than maybe upgrade down the road..
Old Feb 6, 2013 | 06:00 PM
  #60
Ill have to remember that turbo later on right now its too much
Old Feb 6, 2013 | 06:31 PM
  #61
TheShodan's Avatar
Moderator
I'd go a bit more with the 57 trim, GT3255B journal bearing or 60 trim for a GS-R over the 50..
Old Feb 7, 2013 | 06:57 AM
  #62
ok thanks i know that 60 trims on there but ill have to see about other one..
honda_ek9
Jan 19, 2011 12:39 PM
96electronH
Oct 7, 2009 07:53 PM
JKov240
Mar 30, 2007 02:25 PM
99jdem18L
Feb 23, 2005 07:51 AM
boosted89si
Aug 27, 2004 04:31 PM
