looking for a shelf kit for a b18c1 setup
Old Feb 2, 2013 | 05:48 PM
  #26
diesel718's Avatar
Default Re: looking for a shelf kit for a b18c1 setup
Originally Posted by DAprojectTuRtle
I found a nice vid on youtube of this exact turbo and it made 430whp just waiting to find out what fuel was used and the power it makes is more than enough and the powerband looked perfect for street. im also putting it in my DA
https://www.youtube.com/watch?v=lGiQ...e_gdata_player
a fellow DA owner good ****!! the only thing i went with from that exact website was the intercooler piping. they were the only ones i found to make the pipes exactly for the DA.
Old Feb 2, 2013 | 05:50 PM
  #27
TheShodan's Avatar
Moderator
Originally Posted by diesel718
smaller turbo=quicker spool but no big power after getting into higher rpm...he would end up maxing boost before having to shift on a WOT depending what his redline is set to.
Not true at all. MANY of these smaller units will do just fine in the upper rpm band, over 7000rpms on sub 2.2 litre VTEC engines.
For any of these street setups used, no real power is gained after 8000rpms anyway. This "bigger turbo" logic is the reason why a lot of these hondas get useless in higher rpms against cars with smaller units that have a better torqueband. Better acceleration, more usable powerband, not some silly peak number to brag about. What good is 400whp on 91 octane if its only used the last 2000rpms of powerband?
  #28
DAprojectTuRtle's Avatar
Probably ID injectors and im going to call whatever company that i buy the kit from and ask them what size for exact kit.. i just posted a vid of this turbo making 430whp.
Old Feb 2, 2013 | 05:53 PM
  #29
wantboost's Avatar
Who is Mr Robot?
Not true at all, with a proper wheel and housing combination you can have both.
Lightningteg made 300/300 on a stock ls with a gt280 and carried the torque flat all the way to redline.
I can make 400 with a gt2871 and have the top end of a bigger turbo (example a 50 trim) but have the down low torque production that peaks and carries where a larger turbo would just start spooling.
Smaller turbo does not equal little power....people needs to get over this idea that they need huge turbos for a tiny power goal and complain because its too laggy and sucks to drive on the street. You wouldn't dd a gt42r on a b16 now would you?
Comparing a 50 trim t04e to a gt2871 is the same comparison. Why have tons of lag and have a shitty power band as well as a narrow rpm range to use.. especially when you could size a turbo properly for your power goal and purpose of vehicle and have a retardedly huge, fat, torque loving power band - see it all the time at our shop and on various forums.
Old Feb 2, 2013 | 05:54 PM
  #30
wantboost's Avatar
Who is Mr Robot?
Dammit Mac you beat me to it :p
PS look at our first words... creepy?_
  #31
thanks shodan about the trannys thats what i figured. could you tell me why you suggest the log manifold over the mini ram?
Old Feb 2, 2013 | 05:56 PM
  #32
wantboost's Avatar
Who is Mr Robot?
Log manifold will provide the bestresponse/spool and support your goals without issue
The ramhorm and top mounts have longer runners which means not only a drop in exhaust gas velocity but in temperature, effectively reducing response.
Old Feb 2, 2013 | 05:59 PM
  #33
wantboost. my car right now is running b18c1/b16 hydro tranny. so in 5th at 70mph is at 4k rpm. ill call go auto and ask them exactly what turbo when it comes down to it but itd be nice to hear others insights wisdom or suggestions.
Old Feb 2, 2013 | 06:01 PM
  #34
what about the turbo paint and charge pipe paint option? recommended? im having the fmic done black so hopefully it wont be seen behind uncut bumper
Old Feb 2, 2013 | 06:04 PM
  #35
TheShodan's Avatar
Moderator
Greg will give you anything in his repertoire you ask. That doesn't mean that every turbo choice you can go through is by that.
Been doing this 15 years.. trust me when I say... GO SMALLER. STAY SIMPLE.
Here's a thread on the manifold choices you wanted to compare. it was in the FAQs.
"Which Manifold is for me?"
https://honda-tech.com/forums/forced-induction-16/why-top-mount-2152865/
Old Feb 2, 2013 | 06:11 PM
  #36
ok thanks.. that thread makes me want the mini ram.
Old Feb 2, 2013 | 06:21 PM
  #37
TheShodan's Avatar
Moderator
For smaller turbochargers like that.. That's the LARGEST you want to do. It's already shown that the log manifold is capable of efficient velocity over 475whp.
  #38
wantboost's Avatar
Who is Mr Robot?
Mini rams have a lot of issues with oil returns, the turbo hangs so low it's almost impossible to properly Mae a return line
  #39
ok
Old Feb 2, 2013 | 06:22 PM
  #40
TheShodan's Avatar
Moderator
Very true.
Old Feb 2, 2013 | 06:24 PM
  #41
thank you guys ill go log manifold then. just gotta figure out what turbo
Old Feb 2, 2013 | 06:25 PM
  #42
wantboost's Avatar
Who is Mr Robot?
The way mos people do it now is with a loop that gods towards the front of the car then to the pan... its angled down hill all the way but on afraid that band could cause oil to pool under hard braking/cornering g forces.
Old Feb 2, 2013 | 06:31 PM
  #43
i doubt id be doing much driving like that but id rather be safe efficient and simple. i guess im going to just get that kit tell greg what motor consists of so as to determine turbo size. Then just rebuild and tune and whatever it makes that tuner considers safe ill be happy
Old Feb 2, 2013 | 07:52 PM
  #44
phaphon's Avatar
yup their right on the mini ram i dont like mines cause of the way it positions the turbo
Old Feb 2, 2013 | 08:03 PM
  #45
redflaredcrx90's Avatar
not all mini rams are mad the same
Old Feb 2, 2013 | 08:14 PM
  #46
lol
Old Feb 3, 2013 | 05:24 AM
  #47
rice a roni's Avatar
made 298hp on 10.5 psi with a garret .50 trim 48 a/r turbo on a stock gsr with 93 octane. of course I only boost 8 psi on the streets but 350hp would be unusable on the street. my tires take a **** once boost hits at 3500-4000 rpms all the way to third.
Posted from Honda-tech.com App for Android
Old Feb 3, 2013 | 05:28 AM
  #48
word then im happy thanks guys. i cant wait all is said and done so i can see what this no tractions about lol jpjp
Old Feb 3, 2013 | 06:20 AM
  #49
its horrible. prepare to purchase and dd on r compound tires...and then you still slip them.
Old Feb 3, 2013 | 07:00 AM
  #50
i wont be doing too many full or even 3/4 throttle passes on the street. trying to preserve my clean driving record. But anyways what intake manifold do you guys suggest for the c1 head? Since p72 choices are limited and bbk doesnt seem to be offering one on their site right now.. Oem or maybe skunk2
