Looking for a MAP Sensor block off plate with no holes.
Looking for a MAP sensor block off plate with no holes in it.
I will be using the AEM 3.5 BAR in a different place.
Re: Looking for a MAP Sensor block off plate with no holes. (MidwestAutoWorks)
I'd say to use the adapter from TunerToys, and you can either put in an 1/8" npt plug, or use the fitting for another item that needs vacuum, ie: BOV..
http://tunertoys.zoovy.com/c=T...APTER
Re: Looking for a MAP Sensor block off plate with no holes. (locash)
Like I said i do not want a hole in it, it can be a piece of .5 aluminum as long as it blocks that hole
NEVERMIND
I just realized that the new throttle body's map hole is threaded, I can just throw a plug in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks »</TD></TR><TR><TD CLASS="quote">NEVERMIND
I just realized that the new throttle body's map hole is threaded, I can just throw a plug in it.</TD></TR></TABLE>
Re: Looking for a MAP Sensor block off plate with no holes. (JSPECSIR)
Could have but Im going for the clean look.
My brother in law who is an engineer has decided to machine a few of these.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote">I'd say to use the adapter from TunerToys, and you can either put in an 1/8" npt plug, or use the fitting for another item that needs vacuum, ie: BOV..
Thanks Joe,
Here is a pic...
The block off plate is an interesting idea. What are you going to use as an alternate location for connecting the MAP?
Craig
Thanks Joe,
Here is a pic...
Craig
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks »</TD></TR><TR><TD CLASS="quote">Could have but Im going for the clean look.
My brother in law who is an engineer has decided to machine a few of these.</TD></TR></TABLE>
You could have also stuck a motorola 3bar or 4bar into an OEM housing and made some extra money fooling the locals at the track.
