Map sensor block off plate?
Old Apr 23, 2003 | 05:28 AM
01ITR#700's Avatar
Default Map sensor block off plate?
Does anybody manufacture these? I'm in need of one for my upcoming 3-Bar map sensor install.
Thanks.
Mark
Old Apr 23, 2003 | 07:47 AM
The Crow's Avatar
Default Re: Map sensor block off plate? (01ITR#700)
I was going to leave my stock map as a block off.
Old Apr 23, 2003 | 07:52 AM
VaporTrail's Avatar
New User
Default Re: Map sensor block off plate? (The End)
you can do that or we make some slick ones.
Old Apr 23, 2003 | 07:53 AM
01ITR#700's Avatar
After a little research I located a Block off plate made by Comptech that they use for their CL Supercharger kits. So the question now is: Do CL's happen to have the same style/size Map sensor as Integra's? If so, then it will work I believe.
Thanks.
Mark
Old Apr 23, 2003 | 07:55 AM
01ITR#700's Avatar
Default Re: Map sensor block off plate? (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail &raquo;</TD></TR><TR><TD CLASS="quote">you can do that or we make some slick ones.</TD></TR></TABLE>
ok, any info? Pics? Price?
Thanks
Mark
JT's Avatar
JT
I use this one from BBK. I'm sure it can be easily made.
Old Apr 23, 2003 | 12:26 PM
boosted3g's Avatar
Default Re: Map sensor block off plate? (JT)
Thats identical to the Edelbrock ones. Id jstu make one. A trip to Lowes and a little work and you have everything.
Old Apr 23, 2003 | 10:53 PM
VaporTrail's Avatar
New User
I don't have any pics, but we make ours out of plastic. It's not worth the effort for us to sell them, but you can easily make your own with some honda bond, a sheet of thick plastic, and some screws.
Old Apr 23, 2003 | 10:59 PM
Kwuaymaikrup's Avatar
Just curious....where do you run the 3-bar map line to? I thought you ran it to the stock location by say drilling and tapping a vac. fitting into the blockoff plate....if I am wrong please let me know. I am about to do my install and just want to be sure. TIA
-Ryan
Old Apr 23, 2003 | 11:23 PM
MiraiZ's Avatar
Default Re: Map sensor block off plate? (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">Just curious....where do you run the 3-bar map line to? I thought you ran it to the stock location by say drilling and tapping a vac. fitting into the blockoff plate....if I am wrong please let me know. I am about to do my install and just want to be sure. TIA
-Ryan</TD></TR></TABLE> I thought the same...I'm assuming they run it off of another vacuum line on the intake mani
Old Apr 23, 2003 | 11:42 PM
Stu's Avatar
Stu
New User
He wants one with a nipple on it.
Old Apr 23, 2003 | 11:48 PM
accordfreak's Avatar
Default Re: (Stu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu &raquo;</TD></TR><TR><TD CLASS="quote">He wants one with a nipple on it.</TD></TR></TABLE>
me too
Old Apr 23, 2003 | 11:52 PM
TurboDANDEE's Avatar
Default Re: (accordfreak)
i just drilled mine and tapped it, plugged it with a 1/8 plug.
Old Apr 24, 2003 | 05:07 AM
JT's Avatar
JT
You want to run a vacuum line from the MAP sensor to the intake manifold, NOT the original location on the TB. Because the sensor needs to see boost.
Edit: perhaps it's different for turbo applications...
Modified by JT at 8:36 AM 4/24/2003
Old Apr 24, 2003 | 06:25 AM
Rory Breaker's Avatar
Where can you get that BBK plate? I looked around and couldnt find one.
Ill leave my sensor ziptied thank you, I just want something to replace Sakai's map sensor that is acting as a blockoff, and I dont want to pay $40 for Inline Pro's fancy schmancy plate.
Theres your answer BTW, Inline Pro offers blockoff plates with a vacuum source, they are $40 if I remember right.
Old Apr 24, 2003 | 07:15 AM
JT's Avatar
JT
Default Re: Map sensor block off plate? (newgsrdriver)
Mine came with a BBK throttle body. But I did make one out of a piece of aluminum. Just drill two holes with the correct mounting spacing. Leave the MAP sensor O-ring at the original location and screw down the plate against the O-ring.
Old Apr 24, 2003 | 09:19 AM
Farnsrocket's Avatar
Obviously this isn't the best finished piece, but I made this out of aluminum in about 10 minutes with a Dremel.
Old Apr 24, 2003 | 09:23 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Map sensor block off plate? (Farnsrocket)
inlinepro has these, i was gonna do something like that so that could run a vaccuum line to the 3-bar MAP
Old Apr 24, 2003 | 09:28 AM
98lude's Avatar
Default Re: Map sensor block off plate? (Boosted97Lude)
I don't understand, but why is there a need for a check valve on the vaccum line? shouldn't it be without the check valve if we are linking it to the map sensor?
Old Apr 24, 2003 | 09:29 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Map sensor block off plate? (98lude)
that just if you are using an FMU and bypassing the MAP, i was more or less concerned with the plate thats on it
Old Apr 24, 2003 | 09:34 AM
98lude's Avatar
hmm.. my fmu sees boost too, and increases at 1:1 ratio..
Old Apr 24, 2003 | 09:35 AM
Boostless97Lude
Guest
Posts: n/a
you don't understand obviously
EDIT: sorry to sound rude, but you just aren't getting the picture
Old Apr 24, 2003 | 09:39 AM
98lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">you don't understand obviously
EDIT: sorry to sound rude, but you just aren't getting the picture</TD></TR></TABLE>
probably not, thats why I ask. Maybe you can enlighten me then.
Old Apr 24, 2003 | 09:43 AM
Boostless97Lude
Guest
Posts: n/a
it acts like a "missing link"
Old Apr 24, 2003 | 09:51 AM
98lude's Avatar
I see where my confusion stems from... I thought we were talking about installing 3 bar map sensor, and obviously, you were trying to talking about using a stock map sensor. Now, I understand the part about using a check valve before the stock map sensor so that it don't see boost, and have a fmu to increase your fuel pressure. What I don't understand is JT's comments when he said that we should not use the source from the TB, but instead tap it from the intake manifold. That, I do not understand.
