CUTOUT AND TUNING?????
Old Apr 27, 2006 | 08:02 AM
FONK's Avatar
Default CUTOUT AND TUNING?????
so i just put a cut-out on my car,we routed it straight off the turbo and goes down to the side,i was tuned for a 2 1/4 xhaust,do i have to re-tune my car for the cut-out,since its a big difference??????and is there any tricks i can do with the tuninig,because i ran the cutout straight off the turbo so theres no o2 bung to plug a wideband.......
Old Apr 27, 2006 | 08:17 AM
drintegra's Avatar
Default Re: CUTOUT AND TUNING????? (FONK)
should have ran the cut out further down to give room for the bungs, it might affect drivability now since there is no O2 reading. the cut out on a friends car did not change the reading too much maybe .2-.3 AFR points. It went from like 10.8 -11.2 through out the power band.
Get an AFR meeter like PLX 300 or UEGO. This will give you an accurate reading and a baseline.
Old Apr 27, 2006 | 08:30 AM
FONK's Avatar
ya,i was goin to but i my i have 3 inch downpipe and then it bottlenecks to a cat then to a 21/4 xhaust
Old Apr 27, 2006 | 08:38 AM
yee SERIOUS's Avatar
don't you just need one o2 bung before the cutout for wideband tuning? i'm sure you can just get one welded on. how far is your cutout from the turbo? 10-12inches?
Old Apr 27, 2006 | 09:21 AM
FONK's Avatar
its about 10 inchs straight
Old Apr 27, 2006 | 10:10 AM
get a pic for us
Old Apr 27, 2006 | 10:57 AM
ccivic's Avatar
Default Re: (undercoverdc2)
retune.
Old Apr 27, 2006 | 11:33 AM
FONK's Avatar
so you think it will make that big of a difference?????
Old Apr 27, 2006 | 11:34 AM
FONK's Avatar
so you think it will honestly make that big of a difference???
Old Apr 27, 2006 | 11:39 AM
SovXietday's Avatar
Default Re: (FONK)
You need to get your O2 inbetween the cutout and the turbo, that's for sure. And yeah, I'd definitely retune.
Old Apr 27, 2006 | 05:50 PM
blackeg's Avatar
Default Re: (SovXietday)
yea, id retune. i have mine tuned at a lil less than 12:1 with my cutout open and with it closed (stock exhaust) im just about 11:1, so it varies up to about a full a/f point. with the cutout open im making a solid 30+more hp than with it closed, and consequently you will need more fuel to compensate
Old Apr 27, 2006 | 08:02 PM
jdm'dc2sc61's Avatar
Default Re: (blackeg)
i have the same setup with the cutout straight off the turbo and no bung for the o2. i haven't gotten my car tuned yet, will this make things more difficult to tune?
p.s. im not tryna jack the thread, i figured we're both in the same situation.
Old Apr 27, 2006 | 11:47 PM
FONK's Avatar
no,completly understanable,i need some answers,hehehe j/k,but how much boost you think i can run with it open i used to run around 17psi
Old Apr 28, 2006 | 01:28 AM
blackeg's Avatar
Default Re: (FONK)
well with it open, everything elsse being the same you should make a few more psi right out of the box, just due to better flow
Old Apr 28, 2006 | 08:41 AM
of course you need a retune. i bet your turbo is gonna spool wayyyyy faster. you want to go lean?
Old Apr 28, 2006 | 09:07 AM
ExVtec's Avatar
Tuning before and after having your cutout open may affect the tune.
Depends on many variables.
I have a 3" exhuast w/a cutout and w/it open it changes my a/fs from 10.9 to 11.4 in boost.
IF you have a stock exhuast and a cutout and are tuned with a stock or somewhat restrictive exhuast, the cutout will dramaticlly make a difference.
Always variables...depends on your application.
Old Apr 28, 2006 | 02:30 PM
FONK's Avatar
do think that 14 psi would be safe!!!!
Old Apr 28, 2006 | 02:46 PM
Dc4turbo408's Avatar
Default Re: (FONK)
with 5 psi u will be super safe
lol, jk..
Old Apr 28, 2006 | 04:22 PM
Naterror's Avatar
Default Re: (FONK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FONK &raquo;</TD></TR><TR><TD CLASS="quote">do think that 14 psi would be safe!!!!</TD></TR></TABLE>
I can tell you this far sure. Tuning it would be safer.
Old Apr 28, 2006 | 04:49 PM
5thgen's Avatar
Default Re: (Naterror)
I've just taken my exhaust off from the downpipe back. From a kteller/magnaflow 3" to just open 3" dp.
It may have changed my a/f by 2 tenths consistently....spool is much quicker though, was able to gain 4-5 psi (9-14psi) at 5000rpm....and a/f stayed where it was supposed to.
LxSedan
Dec 19, 2005 08:03 AM
ScottEK
Aug 8, 2003 06:58 PM
gcajnr21
Jan 29, 2002 10:46 PM
