just went turbo...smoking need help
i just installed a turbo kit that is custom...im using a t3/t4 setup. I installed it and now its hard for me to start up in the morning and it back fires a alot. when i first put it in my b18b it was smoking grey...its not as noticable now...please help.
Re: just went turbo...smoking need help (tuner_3)
If you're having grey smoke at start up and backfires a lot, it means you're idling too rich. What kind of engine management are you currently running?
Re: just went turbo...smoking need help (green_GSR)
i just put it in tuesday...the setup im running is an vortech 12:1 fmu, stock injectors, aem fuel rail, vortech fpr, stock ignition, magnacore wires, missing link, delta wastegate, t3/t4 turbo walbro 255 fuel pump. I figured it would be that problem but how? It feels fine when gunned half throttle but at a idle it feels as if its going to die...flooding of some sort...i want to get it tuned but i want to know whats going on before i go...could it be a vacuum problem...please help...thanks...oh yeah...check light comes on when gunned full throttle at 5k or so...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuner_3 »</TD></TR><TR><TD CLASS="quote">i just put it in tuesday...the setup im running is an vortech 12:1 fmu, stock injectors, aem fuel rail, vortech fpr, stock ignition, magnacore wires, missing link, delta wastegate, t3/t4 turbo walbro 255 fuel pump. I figured it would be that problem but how? It feels fine when gunned half throttle but at a idle it feels as if its going to die...flooding of some sort...i want to get it tuned but i want to know whats going on before i go...could it be a vacuum problem...please help...thanks...oh yeah...check light comes on when gunned full throttle at 5k or so...</TD></TR></TABLE>
check to see what that CEL is for..
how much boost are you running ? see if that missing link still works.
btw i dunno what you mean by tuned. not much to tune there to be honest with ya.
Re: just went turbo...smoking need help (project dc2)
i want to get it tuned by using urbendata or hondata...something with better fuel maps...how would u know if a missing link is bad? the car studders when driving normally...why? what could be the possiblities? I dont know this is the first time i turbocharged my teg...please help.
