Turbo Help
Old Sep 17, 2006 | 07:15 AM
nicktagz's Avatar
Default Turbo Help
I'm having trouble with my car after installing a t3/t4 turbo onto it. I'm using a fmu with an inline fuel pump and a front mount intercooler. The problem is that the car starts ok and idols ok but when i try to accelerate its sputters and feels like the engine is going to stop. So my thought is that its a fuel problem but I'm not sure.
Old Sep 17, 2006 | 08:09 AM
someone else's Avatar
It Wasn't Me!
Default Re: Turbo Help (nicktagz)
What else did you change? Still on stock injectors? And when you say T3/T4 are we talking ebay kit or a reputable brand? You'd probably be better off in the FI forum.
Old Sep 17, 2006 | 10:13 AM
BlUAc's Avatar
Default Re: Turbo Help (someone else)
it might be what kind of fmu you using and how much you trying to boost stock injectors with a fmu is ok dont want to get bigger ones with it
Old Sep 17, 2006 | 10:41 AM
twkdCD595's Avatar
What are you using to keep the map sensor from seeing boost since your only running an fmu?
Also have you any clue what your a/f is? or timing? (hopefully your running some kind of retard in the timing and not just stock n/a timing)?
Seems like we need ALOT more information before forming any conclusions... you could have quite a few problems that would need be addressed.
Tell us everything...
Old Sep 18, 2006 | 07:44 PM
nicktagz's Avatar
Default Re: Turbo Help (twkdCD595)
I'm using a 12:1 fmu with the stock injectors and an inline fuel pump and I'm using the missing link piece to hide the boost from the map sensor. I haven't touched the timing though cause I though it was controlled by the computer.
Old Sep 18, 2006 | 10:08 PM
iam7head's Avatar
are you getting good vaccum and how much you boost peak off?
is the wastegate properly hooked up?
sounds like the map sensor is seeing boost, what type of missing link is it?
Old Sep 19, 2006 | 05:47 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicktagz &raquo;</TD></TR><TR><TD CLASS="quote">I'm using a 12:1 fmu with the stock injectors and an inline fuel pump and I'm using the missing link piece to hide the boost from the map sensor. I haven't touched the timing though cause I though it was controlled by the computer.</TD></TR></TABLE>
sounds like you've got the bases covered there. what year is your car?
My guess is that you have the FMU lines hooked up backwards. Double check the fuel lines going to/from the FMU and ensure they are in the correct places.
You're using the return line from the rail to feed the FMU, correct?
Old Sep 19, 2006 | 07:59 AM
nicktagz's Avatar
Default Re: Turbo Help (notoriousB)
I'm pretty sure its hooked up right cause that was my guess too but the fmu didn't come with instructions. I have the nipple thats on the side of the fmu going to the FPR and the nipple piece in the dead center of the fmu going to the return line that I removed from the FPR and the vaccum piece on top is spliced into the FPR's vaccum line. This is the missing link I'm using
Old Sep 19, 2006 | 08:13 AM
1slowdc2's Avatar
What about your spark plugs? Did you change them or at least re-gap them?
Old Sep 19, 2006 | 08:23 AM
nicktagz's Avatar
Default Re: Turbo Help (1slowdc2)
yea bkr7e-11 gapped to .030
Qwik_XR
Jul 4, 2006 12:06 PM
laakea
Apr 3, 2006 07:13 PM
stussy8280
Sep 5, 2005 06:31 PM
eg6T
Oct 28, 2004 07:31 PM
highmilehatch
Aug 30, 2003 08:26 AM
