missing bolt on manifold
Old Aug 26, 2005 | 07:25 AM
tegh22a's Avatar
Default missing bolt on manifold
my friend has a turbo b16 and he is missing the middle bolt on the exhaust manifod, how long do you think he can drive without the manifold cracking. its daily driven at 7 psi no internals?
Old Aug 26, 2005 | 07:51 AM
Flamenco-T's Avatar
Default Re: missing bolt on manifold (tegh22a)
is he missing the head to manifold bolt ? that'll be fine, just have it replace soon
stan
Old Aug 26, 2005 | 07:58 AM
tegh22a's Avatar
Default Re: missing bolt on manifold (Flamenco-T)
the middle one in front of the oil dip stick, the hole is stripped and will that manifold crack?
Oh and how do you fix the hole that is stripped?
Old Aug 26, 2005 | 08:02 AM
xenocron's Avatar
Helicoil or redrilling and tapping
Old Aug 26, 2005 | 08:27 AM
Flamenco-T's Avatar
Buy a stud remover, drill it through, hammer it in and turn it counter clockwise.
stan
Old Aug 26, 2005 | 08:31 AM
tegh22a's Avatar
the bolt is already out. so i will have to tap the hole to rethread it?
Old Aug 26, 2005 | 08:33 AM
Flamenco-T's Avatar
if it's stripped, you'll need to recoil it, becasue the next size up is 10x1.25mm which is too big for the manifold flange hole.
stan
Old Aug 26, 2005 | 08:56 AM
tegh22a's Avatar
how long do you think that will take and how much??
Old Aug 26, 2005 | 09:11 AM
angela_itr's Avatar
Was the bolt taken out to stop the plastic on the dipstick melting? Someone suggested I do that on my Drag mani, as the bolt transfers heat to the dipstick apparently.
Old Aug 26, 2005 | 09:15 AM
tegh22a's Avatar
Default Re: missing bolt on manifold (angela_itr)
no it was just loose, and how long have had that bolt off?
Old Aug 26, 2005 | 09:22 AM
dunkd's Avatar
one of my nuts had the head crack off (hehehehehe)
theauthor17
Aug 8, 2008 11:47 AM
GrandMarkie
May 17, 2002 12:53 PM
