Update on my planned setup
Old Jun 25, 2002 | 06:58 PM
M.A.R.C.'s Avatar
Default Update on my planned setup
OK I've changed the plans on my setup thus far... I decided to go external wastegate with the T3 turbo.
>Garrett T-3 Turbocharger (.60A/R, 60-trim comp, .48A/R turbine)
>Starion Intercooler
>Apex'i Twin Chamber Blow Off Valve
Pann Auto Turbo Manifold
Custom Charge Pipes
Custom Downpipe
Tial 35mm .45 Bar Wastegate
Fuel System:
>DSM 450cc Injectors
>88-91 Injector Resistor Box
>255lph Walbro High Pressure Intank Fuel Pump FPH003
>Calterm GM Injector harness clips
Electronics & Gauges:
>Apex'i V-AFC
>Greddy Turbo Timer
>Autometer Sport-Comp A/F Ratio Gauge
>Autometer Sport-Comp Boost Gauge
>Autometer Dual Gauge Pod
>NGK BCPR7ES-11 Spark Plugs (0.032 gap)
Miscellaneous:
Turbo Performance Oil Line Kit <-- probably gonna go with ALL -AN lines for return... dunno for sure
Vacuum hoses
Silicone couplers
Misc.
I have purchased everything with the > next to it. Any recommendations, comments, flames, etc? Anybody got any of the parts I need for sale?
Old Jun 25, 2002 | 07:07 PM
PrecisionH23a's Avatar
Default Re: Update on my planned setup (CivicRyda2k)
a boost controller would also be a very good investment, i recommend either greddy profec a or the apexi avc-r. you can always make your own manual one though, just depends on the type of options you want. I would also invest in a missing link map sensor. And once you are part of the wonderful world of turbo, i would highly recommend having a nice travel along tool kit to carry with you.
Old Jun 25, 2002 | 07:11 PM
Anubyss's Avatar
I don't see a boost controller unless you are just going to let the wastegate handle it. Also you might want to think about switch the a/f for an egt gauge. Stock oxygen sensors aren't very accurate which makes the a/f gauge not very reliable. Just a suggestion though.
Old Jun 25, 2002 | 07:13 PM
M.A.R.C.'s Avatar
Default Re: Update on my planned setup (GudeH23a)
Thanks for the recommendations. I do plan on getting a boost controller but I'll be sticking to 7psi for a while. Also I don't need the Missing Link Valve because I'm using the AFC hack and I'm gonna boost below 10psi anyway. And OH YES... best believe I'm planning for that travel along "first-aid kit"
Old Jun 25, 2002 | 07:14 PM
M.A.R.C.'s Avatar
Default Re: Update on my planned setup (Anubyss)
ya my thoughts exactly. I do plan on an EGT as soon as this is all in as well.
Old Jun 25, 2002 | 07:31 PM
M.A.R.C.'s Avatar
ttt
RedTegLS
Oct 15, 2003 08:08 AM
TurboJesse
Feb 17, 2003 08:00 PM
M.A.R.C.
Aug 26, 2002 12:33 PM
M.A.R.C.
Jul 7, 2002 10:09 AM
M.A.R.C.
Jun 18, 2002 01:17 PM
