ITR SURPRISE!!
Old Nov 4, 2006 | 08:36 PM
eg_gsr11's Avatar
Default ITR SURPRISE!!
Hey guys i have run into a problem. today as me and my buddies were changing my head gasketr and putting my turbo kit on i discovered that i have ITR pistons. i thought they were je 9.0:1 compression. (thats what you get fro buying a car offline) what would be a safe boost level and what boost level could i max out with allong with a good tune?
Old Nov 4, 2006 | 09:24 PM
themorphious's Avatar
you could max out at 1 psi with no tune....you could prolly push a little more than 1 with a good tune
lol
Old Nov 4, 2006 | 09:39 PM
CRXdan's Avatar
Default Re: ITR SURPRISE!! (eg_gsr11)
what turbo. how many kms on the engine. what are your power goals.
Old Nov 6, 2006 | 03:01 PM
eg_gsr11's Avatar
Default Re: ITR SURPRISE!! (CRXdan)
its a .50 trim turbo and i have 50,000 on the engine. my power goals are 10 psi with a good tune
Old Nov 6, 2006 | 03:02 PM
eg_gsr11's Avatar
Default Re: (themorphious)
very funny themorphious
Old Nov 6, 2006 | 03:06 PM
RedEj8's Avatar
Default Re: (eg_gsr11)
What motor is this? Its all in the tune..10psi could be done very easily with a good tune.
Old Nov 6, 2006 | 03:18 PM
PrecisionH23a's Avatar
I would stop around the 300whp marker if it's a daily driver.
Old Nov 6, 2006 | 07:34 PM
eg_gsr11's Avatar
Default Re: (RedEj8)
its a b18c1. i have a p28 ecu that chipped and tuned for 7 psi, also a set of 450 dsm injectors helps with the fuel, msd full ignition allong with msd dist. type r camshaft and skunk 2 manifold, springs, valves and retainers. im not sure about the rods but i was told that they were eagle. bu considering i was told i had 9.0:1 compression i can be too sure about the rods so i'll just say that theyre stock. i plan on tuning very soon and whould like to know from you guys what to prepared for.
Old Nov 6, 2006 | 10:19 PM
HiProfile's Avatar
I'd have to say the pistons, specificly the ringlands, would be the weak link. Next in line is the ecu - pre-tuned for a different setup means its just a basemap. It will likely have too much timing on the map. 7psi on a stock ITR isn't all that bad - theres quite a few ITR motors that are boosted, but they usually get a dyno tune.
I just wouldn't feel safe running a pre-tuned map (for 9:1, but having 11 or 12:1), itr cams, and especially DSM injectors. They are known to fail more frequently than most injectors, as well as maxing at 300whp even with a high-flow fuel pump.
Old Nov 7, 2006 | 06:17 AM
blaze the chemi's Avatar
Default Re: (HiProfile)
Why don't you open up the oil pan and take a looksee about your rods? That way you could at least feel more comfortable. I'd agree with most people here that keeping the boost at 10 psi or lower, allowing to keep the stock MAP sensor, would be safe. If you have a MBC then I would keep it at low boost for DD and crank it to 10 for the track. Time to keep filling up with high octane.
Old Nov 7, 2006 | 07:01 AM
b18sihatch's Avatar
pull the pistons/rods and beat the person woh lied to you about them!
10psi will be fine with a good tune, and you will make real close to 300whp
Old Nov 8, 2006 | 04:11 PM
eg_gsr11's Avatar
Default Re: ITR SURPRISE!! (b18sihatch)
thats some great advice. i wish i could shove the pistons up his... oh well looks like i have to settle for 300hp i guess right? thanks for the info guys. great help!
Old Nov 8, 2006 | 04:14 PM
b18sihatch's Avatar
people are liars but remember karma is a bitch, so he will get his no doubt
hatch34
Feb 5, 2008 10:57 AM
DC4R27
Oct 6, 2007 07:34 PM
ScorpioX
Sep 23, 2004 11:20 AM
dc2Rgirl
May 4, 2004 04:18 PM
the jdmchop
Feb 29, 2004 01:48 PM
