internal to external wastegate
Old Nov 8, 2005 | 06:09 PM
PURO~SURCAL's Avatar
Default internal to external wastegate
i got a airsearch t3 turbo with a internal wastegate thats all F-ed up..i took it all apart and was wondering if i can weld a parts on the turbo where the external wastegate use to be and use it as a normal turbo and go with a external wastegate..is this possible
Old Nov 8, 2005 | 06:30 PM
turboeg77's Avatar
Default Re: internal to external wastegate (ALL_MOTOR_EG6)
we tried welding the flap shut ofa t25 but it kept cracking on the welds. we ended up just putting a stop screw on the down pipe flange to push the flap shut. it works well
Old Nov 8, 2005 | 10:03 PM
liam821's Avatar
25 Year Member
Default Re: internal to external wastegate (turboeg77)
Totally doable. Just weld the door shut really well, and then use an external gate.
Old Nov 8, 2005 | 11:05 PM
Default Re: internal to external wastegate (liam821)
cool thanks guys
Old Nov 9, 2005 | 07:28 AM
HiProfile's Avatar
Or do it a better way for cheap - buy a 5-bolt flange & gasket that doesn't have the cutout for the wastegate hole, put it between the wastegate and turbine housing (maybe get longer bolts too) - finsished. You can now reuse your DP w/o welding too, although its a moot point if you're getting a different manifold.
Old Nov 9, 2005 | 09:27 AM
liam821's Avatar
25 Year Member
Default Re: internal to external wastegate (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Or do it a better way for cheap - buy a 5-bolt flange & gasket that doesn't have the cutout for the wastegate hole, put it between the wastegate and turbine housing (maybe get longer bolts too) - finsished. You can now reuse your DP w/o welding too, although its a moot point if you're getting a different manifold.</TD></TR></TABLE>
One problem with that is if the flange comes loose or leaks any, you have no boost.
Its annoying...
liam
trav39562
Jan 4, 2009 01:33 PM
blackmugensivic
Dec 18, 2007 09:03 PM
redlseg
Jul 20, 2005 10:31 PM
abmerop18
Jan 27, 2005 08:05 AM
Nextelbuddy
Jun 9, 2003 10:13 AM
