changing a internal wastegate turbo into a external wastegate?
Re: changing a internal wastegate turbo into a external wastegate? (EK_GSR)
Hey! I finally know something.
It's done all the time though. As far as I know all you'd have to do would be weld the wastegate flapper shut, and remove that wastegate thingie, and use an external wastegated manifold and you're all gravy.
Re: changing a internal wastegate turbo into a external wastegate? (300whpOrBust)
It depends on which kind of turbo you have. Some turbos have a wastegate flapper that is an integral part of the turbine housing. If so, the flapper must be welded shut and actuator removed.
Other turbos have a flapper that are not part of the turbine housing but simply bolt on as a separate piece. My turbo for example, came with an internal gate but because the flapper was a separate piece, I simply unbolted the flapper and actuator and used an external gate.
Either way, it's not that hard to switch.
Here are some pics of what I'm talking about. <--- can you tell I'm bored today? LoL.
Turbo with a flapper which is part of the turbine housing and must be welded shut: (my dream turbo the gt28rs!)
Here's one like mine, well, this is the turbo that I have, you can see that the flapper can be unbolted.
Re: changing a internal wastegate turbo into a external wastegate? (EJ1 wilcox)
thax for the pic bro . but i'm kind of confused what does the flaper look like on the pic?
Re: changing a internal wastegate turbo into a external wastegate? (redlseg)
is this the flapper? and yes my shoe is up for sale if anyone is interested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlseg »</TD></TR><TR><TD CLASS="quote">is that the flapper?</TD></TR></TABLE>
Yes.
Yes.
Re: changing a internal wastegate turbo into a external wastegate? (Pondus)
i have never scene an exhaust housing like that before! crazy how the 3 bolt flange is actually a seperate plate you bolt onto the housing.
mmm...gt28rs i have the gt28r and i cant imaginea more responsive turbo!
Its really quite simple. All i did on my wrx turbo was weld the flapper shut and weld a flange onto my hf manifold to fit the tial wastegate.
abmerop18
01-27-2005 08:05 AM
