internal to external wastegate
Old Dec 17, 2007 | 09:43 PM
blackmugensivic's Avatar
Default internal to external wastegate
First off yes i searched....Now my question, can you somehow disable an internal wastegate on a turbo so that you can run an external one on your manifold?
Old Dec 18, 2007 | 12:30 AM
ridin98civic's Avatar
Default Re: internal to external wastegate (blackmugensivic)
yes there is. remove the internal wastegate actuator arm and spring housing, then weld the internal gate shut. if your manifold isnt already built for it have a flange welded to it for the external gate, bolt on the external and hook up your hoses.
Old Dec 18, 2007 | 10:51 AM
Default Re: internal to external wastegate (ridin98civic)
cool thats kind of what i thought but i didn't want to screw up my turbo
Old Dec 18, 2007 | 09:03 PM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackmugensivic &raquo;</TD></TR><TR><TD CLASS="quote">cool thats kind of what i thought but i didn't want to screw up my turbo</TD></TR></TABLE>
If you have the room, you can keep the internal wastegate actuator bracket and just run a long solid bolt. This will keep the internal wastegate flapper shut at all times. This would prevent you having to weld anything or mess up your turbine housing.
trav39562
Jan 4, 2009 01:33 PM
CTR_B
Apr 18, 2008 10:09 AM
redlseg
Jul 20, 2005 10:31 PM
abmerop18
Jan 27, 2005 08:05 AM
