Intercooler predicament
Old Mar 17, 2012 | 05:52 PM
SleeperGSR-T's Avatar
Default Intercooler predicament
Just picked up a spearco to replace my ebay cooler.
I noticed late that the 2in inlet and 2.5in outlet are on opposite sides.
Would it be very bad to run it as-is with 2.5in inlet 2in outlet?
Cant flip it or turn it around bcuz the in/outlets are slightly offset.
Id like to avoid modifying and welding if possible but if its going to be a real problem I will
Old Mar 17, 2012 | 05:55 PM
TheShodan's Avatar
Moderator
Default Re: Intercooler predicament
yes. turn it around, you're fine. 2" inlet, 2.5" outlet to the intake pipe.
Old Mar 17, 2012 | 06:28 PM
My piping might not go on. The in/outlets point towards the engine a bit. If I turn it around they will point towards the bumper
Old Mar 18, 2012 | 03:00 PM
Ok I guess im just gonna do it right and pull all the lower piping and find the best way to modify the setup for a clean and simple fit. Ill post pics of whatever cutting/welding I figure out. Ill have to get it done before work, during breaks, and at lunch so the project might be tedious.
PreludeJunkie91
Oct 3, 2018 11:22 PM
wantboost
Jan 31, 2012 09:23 AM
almostboostedgsr
Jul 5, 2007 12:51 PM
1 Cam Wonder
Dec 10, 2004 04:15 PM
ID_ten_T
Aug 14, 2003 04:58 PM
