:: diy intercooler piping ::
Old Aug 13, 2003 | 04:32 PM
ID_ten_T's Avatar
Default :: diy intercooler piping ::
i am going to try to make my own intercooler piping from jcwhitney u-bends. anyways, i was wondering what you DIY-ers use to cut the piping. the best thing i have at home is a dremel which i know will not be good enough. but i was thinking of renting a circular saw from home depot. what do you think? would this work? any recommendations (size, speed, etc)? all your help would be greatly appreciated. thanks in advance.
Old Aug 13, 2003 | 05:03 PM
BodyKits NW's Avatar
Default Re: :: diy intercooler piping :: (ID_ten_T)
I used a hand saw and a marker to do my piping! Turned out awesome.
Old Aug 13, 2003 | 06:06 PM
Matt B's Avatar
a hack saw works fine.
Old Aug 13, 2003 | 06:16 PM
_jester_'s Avatar
If you rent anything, get a sawz-all! Cuts like butter!!
Old Aug 13, 2003 | 06:23 PM
ghettocrxsi's Avatar
Default Re: :: diy intercooler piping :: (XratedSi)
I used our comound miter saw with a 10" cutting blade. The blade was like 4 dollars at home depot
Old Aug 14, 2003 | 10:18 AM
krazy's Avatar
Default Re: :: diy intercooler piping :: (ghettocrxsi)
sawzall, or a grinder with a metal cut off disc. circular saw wont work too well, its hard to find a metal cutting blade that small. they are usually like 14 inches. also, some piping like SS is really hard, so u'll go thru some sawzall blades like nothing. grinder is like 10-20 bucks at harbor freight, and a pack of metal discs are like 5 bucks.
krazy
Old Aug 14, 2003 | 10:49 AM
BROOD's Avatar
Default Re: :: diy intercooler piping :: (krazy)
FYI: If you happen to be using AL piping, a sawzall is not a good choice. Anything like that will grab the tubing half way through and bend it out of round. It is a real b!tch. A fine tooth hacksaw by hand worked out to be the best in my case.
**now that I think of it, all that work though and now I want to fab CF charge pipes **
Old Aug 14, 2003 | 10:54 AM
quikB18B's Avatar
I used a hacksaw a few days ago. It cuts but your arm will hurt, I say take it up to a shop they can cut them in a matter of seconds . I made 5 cuts myself(took about an hr w/breaks) took pipes to jotech adn the cut last pipe in 5 seconds .
Old Aug 14, 2003 | 11:08 AM
FuzzyGreen's Avatar
How about a chop saw with a metal cutting blade, that should make it easy.
Old Aug 14, 2003 | 11:21 AM
ScrapinSi's Avatar
exhaust tubing cutter works best.... either a circular bladed one or a chain cutter...
Old Aug 14, 2003 | 11:27 AM
Bailhatch's Avatar
Default Re: :: diy intercooler piping :: (ScrapinSi)
A hacksaw is by far the most appropriate tool for a DIY piping job. If you have a sharp, fine tooth blade (as mentioned above) it will go quickly and easily. If it takes you an hour!! to make 5 cuts then the blade was in upside-down... I'm pretty sure I could make 5 cuts in under 5 minutes in steel 2.25" tubing, no 4 minutes.
Old Aug 14, 2003 | 11:34 AM
Greyout's Avatar
you can get a $70 electric one, or this $20 thing...
not sure of the max OD
Old Aug 14, 2003 | 11:38 AM
axhandler's Avatar
Default Re: :: diy intercooler piping :: (Bailhatch)
http://www.homedepot.com/prel8...=9876
sorry it's the heavy duty deep cut band saw...first one listed on the jigsaw page under the power tools menu.
That's what you need! You can rent one if you don't have the 300 bones to buy it.
Old Aug 14, 2003 | 11:49 AM
gritsak's Avatar
Default Re: :: diy intercooler piping :: (axhandler)
air die grinder and cut-off wheel...and sawz all...thats what we used on my friends
Old Aug 14, 2003 | 11:51 AM
autoEXturbo's Avatar
Default Re: :: diy intercooler piping :: (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">I used a hand saw and a marker to do my piping! Turned out awesome. </TD></TR></TABLE>
Yep, that's the way to go
Old Aug 14, 2003 | 11:55 AM
hulkhb's Avatar
Default Re: :: diy intercooler piping :: (gritsak)
i use a 10" chop saw with a metal cutting blade. cuts very fast and clean. I just got done last night doing me complete 3" exhaust with it........now time for charge pipes.
Old Aug 14, 2003 | 12:47 PM
SDT Project EF's Avatar
Default Re: :: diy intercooler piping :: (hulkhb)
sawz-all!
Old Aug 14, 2003 | 01:09 PM
SOFLSOL's Avatar
sawz-all man.. rocked!
Old Aug 14, 2003 | 01:10 PM
meanteg's Avatar
New User
Default Re: :: diy intercooler piping :: (SDT Project EF)
Go to your local tool rental store, and rent this for about 20 $ a day .
Old Aug 14, 2003 | 01:20 PM
redlinegsr's Avatar
a grinder / cutting wheel works great......a sawz-all will too
Old Aug 14, 2003 | 01:24 PM
AlLMoToRvOtEr's Avatar
Take your measurements and mark everything and take it to your local exhaust shop, I will guarantee that they have a circular saw with a metal cutting blade.
Old Aug 14, 2003 | 02:56 PM
Accord94DX's Avatar
screw hacksaws....a cheap tubing cutter works the best!!
Old Aug 14, 2003 | 04:18 PM
RenoRacing's Avatar
Default Re: :: diy intercooler piping :: (Accord94DX)
14" metal bladed chop saw here, and a 4" grinder for the smaller cuts or the air powered die grinder w/ 3" blades. One tip that i found useful was not to bother w/ the 4" cut off wheels, get the 4" grinding discs, they are thicker and last way longer than the cut off wheel. Scored the chop saw for 50$ at harbor freight. good tool!
Old Aug 14, 2003 | 04:58 PM
Neptune's Avatar
Rent/buy a nice circular saw and cut it that way. Or take more time and use a hack saw. But if your ic piping is hard metal, this might take a while.
RuthlessEF-9's Avatar
i did mine by hand.. came out nice
jsnm
Sep 19, 2006 06:43 AM
forcedaccord95
Welding / Fabrication
May 13, 2005 08:19 PM
usdmcivic94
Mar 20, 2005 07:58 PM
VTEC-DA
Feb 5, 2003 09:35 AM
