Installing Piston Pins
Old May 29, 2005 | 03:20 PM
prelude1911's Avatar
Default Installing Piston Pins
I am trying to put the pistons pins in but don't know how to get the little circular springs in that keeps the pins from coming out? Have anyone ever done this? Pics??? The type if pistions are Wiseco H22 pistons. Any help would be appreciated. Thanks
Old May 29, 2005 | 03:30 PM
EnzoSpeed's Avatar
Default Re: Installing Piston Pins (prelude1911)
You just put one end in, then work in a circle, working the clip in. It shouldn't be that hard - when you get towards the end, use needle nose pliers the pop it in.
Old May 29, 2005 | 03:38 PM
D@nnY's Avatar
make sure the 2 indentations on the rod journal are on the exhaust side of the psiton with the smaller valve reliefs. Use a small screw driver to give you some leverage to pry it down into place and the push the pin to lock it into place
Old May 29, 2005 | 04:16 PM
earl's Avatar
Are they shaped like a circle or like a C?
Old May 29, 2005 | 06:55 PM
Default Re: Installing Piston Pins (earl)
They are like a C.
Old May 29, 2005 | 08:28 PM
earl's Avatar
just squeeze them with your fingers then. Don't use pliers because if you bend them too much, they will stay bent and won't hold. Aim the gap in the C toward the top of the piston. Use a small flat bladed screw driver to help you pop them in place.
SPOOLINmatt
Apr 7, 2005 08:48 AM
W O T
Mar 30, 2005 05:59 PM
LSVtechnologytur...
Feb 22, 2005 05:41 AM
stackz
Feb 21, 2005 01:48 PM
Ri5e
Aug 1, 2002 09:34 PM
