Putting in the Retainer Clip for the Piston?
Old Aug 1, 2002 | 12:23 PM
Ri5e's Avatar
Default Putting in the Retainer Clip for the Piston?
I'm having trouble putting in the retainer clips (JE Pistons) for the piston to hold the pin in place. Any tricks?
Old Aug 1, 2002 | 12:35 PM
Ri5e's Avatar
Default Re: Putting in the Retainer Clip for the Piston? (BG Boost)
Nevermind, got it in with some force
Old Aug 1, 2002 | 01:25 PM
PrecisionH23a's Avatar
good job, a good tool to use is a dental tool pick, get the straight, the 45, and the 90deg ones.
Old Aug 1, 2002 | 09:34 PM
Ri5e's Avatar
Default Re: Putting in the Retainer Clip for the Piston? (GudeH23a)
I found the trick, put one of the clip ends into the groove (JE Piston) then push in the middle of the clip and that'll force most of the clip into the groove. Then push the other end in.
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
cyanid3
May 30, 2014 10:36 PM
GruvyTune
Jul 16, 2002 09:14 PM
ek
Jun 10, 2002 08:52 AM
supergreenNA1
Mar 24, 2002 02:19 AM
