Arias wrist pin locks
Old Feb 19, 2005 | 11:07 AM
LSVtechnologytur...'s Avatar
Default Arias wrist pin locks
I was just wondering how the hell these things go in. They are not normal snap rings that I'm use to... with the two holes that you can use snap wring pliers on.
Thanks in advance for any help
Old Feb 19, 2005 | 11:09 AM
Antilag's Avatar
Default Re: Arias wrist pin locks (vtec'n)
You need to carefully pull them apart like a spring and just start with one end in your piston groove and twist them in. hope this helps.
Old Feb 19, 2005 | 11:12 AM
Antilag's Avatar
Default Re: Arias wrist pin locks (9sech22civic)
Or in other words feed the rest in in the same motion as the rings untill all is in.
Old Feb 19, 2005 | 11:37 AM
ohhh ok, thanks alot
Old Feb 19, 2005 | 01:08 PM
is there any other way? I'v been trying for over an hour and it just keeps binding up and wont screw in past 1/4 of the way.
Old Feb 21, 2005 | 09:46 AM
TOM J's Avatar
Old Schooler
If you are having a problem installing the locks send me your pistons and rods and I will install them for you.
Tom J
Old Feb 21, 2005 | 06:33 PM
rjay8604's Avatar
I just got done doing this, stretch the rings a little so they look like coil springs. Put the end in towards the bottom first, then push the rings down into the pin bore as much as possible, then take a ballpoint pen and "trace" around the circumference of the circle until it pops into the groove. Also if you apply a twisting force you can make the clip flex enough to decrease the diameter, and then it will go in easier.
Old Feb 21, 2005 | 07:31 PM
Default Re: Arias wrist pin locks (rjay8604)
thanks guys, i actually just got done installing them. .. .tricky little suckers
Old Feb 22, 2005 | 05:41 AM
Antilag's Avatar
nice one
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
98Luder
17
Dec 18, 2012 02:07 AM
stackz
Feb 21, 2005 01:48 PM
garados
Jan 17, 2004 06:25 AM
SIK IN DA HED
May 16, 2003 09:50 AM
