how strong are d15's??
Old Jun 18, 2004 | 09:23 AM
hatchback_al's Avatar
Default how strong are d15's??
hey guys im curious, how strong are d15 motors? im guessing a bit weaker than d16's but i see guys running some good boost on the jdm d15 motors. Im thinking i might use my spare d15 just as a test motor, but i wont if it's gonna pop immediatly, thats not worth my time. The motor is a 160K mile d15b7 it always ran very strong and never burned or leaked anything. I would run the IHI rhb5 turbo at stock 8lb wastegate, hf mani, walbro pump, 450cc injectors, afc , small fmic, some sort of a turboedit map for my chipped ecu, maby a little dyno tuning.
Old Jun 18, 2004 | 10:20 AM
Sketch_hs's Avatar
Default Re: how strong are d15's?? (hatchback_al)
boost it.
so what if it blows, you can pick up d15b7s for like 100 bucks
Old Jun 18, 2004 | 12:22 PM
Default Re: how strong are d15's?? (Sketch_hs)
i need this car to get to work and back, if its just going to blow immediatly that would be very inconvenient regarding my work schedule...
Old Jun 18, 2004 | 12:27 PM
tgreaves's Avatar
With that turbo you should be fine.. Just remember, tuning is everything.. You can blow a b16 with that turbo and 3 psi or you can run over 10 psi with a T3 on a d15 and make it last forever..
Old Jun 18, 2004 | 12:54 PM
Bailhatch's Avatar
Default Re: how strong are d15's?? (tgreaves)
I think the big issue, aside from tuning, is the mechanical strength of the rods.
Old Jun 18, 2004 | 01:10 PM
Slammd Sol's Avatar
i ran 6psi on my d15b7 for over a year.. Had 130k on it. Ran great and never acted up
tgreaves's Avatar
Default Re: how strong are d15's?? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I think the big issue, aside from tuning, is the mechanical strength of the rods. </TD></TR></TABLE>
They are really weak but again good tuning can get alot of power out of them..
Old Jun 18, 2004 | 01:12 PM
Vtec92Civic's Avatar
tuning is key on any setup . . . be it NA or Forced Induction. If you run to lean well then you run into problems. Boost that motor and just spend a little time reading about fuel managment. Do things right and you'll be good
exratedaccord93
Mar 5, 2011 12:14 PM
stocker2shocker91
Jul 14, 2010 03:54 PM
slammed_94s10
Sep 13, 2009 06:00 PM
bigandy90
Feb 14, 2008 01:57 AM
