d16
Old Sep 13, 2009 | 04:30 PM
slammed_94s10's Avatar
Default d16
i have a 94 civic with the d16 vtec. I was wontig to know what was the most amount of boost i could run safely on a stock motor. i have the t3/t4 turbo. thanks in advance.
Old Sep 13, 2009 | 05:31 PM
turbo_d's Avatar
Default Re: d16
i'd run about 10 lbs on a stock motor, or 8 to be on the safe side
Old Sep 13, 2009 | 05:32 PM
Default Re: d16
ok thats what i was thanking thanks
Old Sep 13, 2009 | 05:38 PM
single cam fan's Avatar
Default Re: d16
are u going to do anything to the motor? Change the hg or anything? I would suggest changing the hg and adding some arp's for added safety on 10 psi.
Old Sep 13, 2009 | 05:40 PM
Boosted-EH-804's Avatar
Default Re: d16
Psi is an arbitrary number its about CFM 10psi from a small turbo is way different than psi from a large one. You need to be worried about power because boost doesnt break **** HP does.......But 250hp is the consensus
Old Sep 13, 2009 | 06:00 PM
Default Re: d16
i going to probly buld the motor this winter.
exratedaccord93
Mar 5, 2011 12:14 PM
power11
Jun 10, 2007 06:47 PM
whatisJDM
Apr 14, 2007 12:49 PM
tdark1582
Apr 9, 2007 08:08 PM
kirk-oire
Jul 23, 2006 07:49 AM
