how to route return line on crx?
Old Apr 13, 2007 | 04:20 PM
josh0407's Avatar
Default how to route return line on crx?
i have a crx with a b16 and moroso oil pan. the fitting i have for the oil pan its my crossmember so i cant even put my return line on there. how do i go about putting on my return line?
thanx josh
Old Apr 13, 2007 | 04:25 PM
4cefedcrx's Avatar
Default Re: how to route return line on crx? (josh0407)
clock your turbo or get traction bars. have fun with that crossmember if you are using a 3" downpipe.
Old Apr 13, 2007 | 05:44 PM
josh0407's Avatar
Default Re: how to route return line on crx? (4cefedcrx)
It Has Nothing To Do With The Turbo. Its The Fitting On The Oil Pan Hitting The Crossmember
Old Apr 13, 2007 | 06:00 PM
jdm28j's Avatar
Seal up that fitting and then get another one welded on somewhere else in its place. That or try and see if u can get an elbow in there thatll clear the crossmember.
Old Apr 14, 2007 | 05:14 PM
Autoworks's Avatar
either...
1. replace the crossmemeber with an aftermarket piece.
2. Notch the crossmember around the return bung leavig plenty of room for the line to move.
3. Plug the OE bung in the pan and weld another bung elsewhere.
4. Use the bung on the back of the pan.
Old Apr 16, 2007 | 08:06 PM
turbomoe's Avatar
Default Re: how to route return line on crx? (Autoworks)
heres the thing,on my old crx b16 turbo my crossmember was causing my return line to cut everytime,cause i had to modify it for my 3" downpipe,so what i did was order me a traction bar from etd racing,guys swore the downpipe would clear,well it didnt,so me and my buddy had to fab it to clear my downpipe,anyways i do have a moroso oil pan as well,and at least the traction bar made so much room for my oil return line,no more problems there,but you would still have to fab up the bar if youre runnin 3" downpipe
Old Apr 17, 2007 | 04:39 AM
Autoworks's Avatar
Default Re: how to route return line on crx? (turbomoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbomoe &raquo;</TD></TR><TR><TD CLASS="quote">,but you would still have to fab up the bar if youre runnin 3" downpipe </TD></TR></TABLE>
That's not true in every case...could just be yours. It depends on the manifold/downpipe combination. Most 3" DPs clear aftermarket crossmemebers/traction bars with no problems.
Old Apr 17, 2007 | 04:54 AM
93supercoupe's Avatar
thats right, most of them do.
Old Apr 17, 2007 | 04:35 PM
josh0407's Avatar
Default Re: how to route return line on crx? (93supercoupe)
el manifold, t4 60-1. i fixed it i put a 90 an fitting off the pan so it went straight up and ran the line. thanx for your input guys
josh
turbo-crx
Feb 27, 2009 09:30 AM
pitoracing24
Dec 4, 2007 04:05 PM
toolowsol
Feb 9, 2006 01:52 PM
WildChild
Sep 15, 2005 08:35 PM
